April 08, 2026, 08:21:49 PM *
Pages: 1 ... 24 25 [26] 27 28 ... 36
Author Topic: The Cunning Coupe  (Read 167174 times)
« Reply #375 on: December 05, 2011, 10:36:19 PM »
Compelling reading Tone! My little truck might not be in the same league, but I share the workshop woes!
It'll be interesting to see this one in action after reading the story behind it.
wizzkitt
« Reply #376 on: December 07, 2011, 12:01:34 PM »
 Grin Grin Grin
« Reply #377 on: December 07, 2011, 12:35:06 PM »
Tell me about cams ! Angry Spent almost 3500 mile strying to sort my A engine with no joy. Swapped out for a low mileage known good lump and trans and still not right. Only thing in common was the cam ?
Got a mate round to check my initial timimg , I've done loads but thought I've got to be making the same mistake repeatedly on thsi one ? I was using valve lift after LTDC and he used full lift after TDC . The two didn't agree?? We reset and retested , still as bad. Looking deeper into it discovered that the actual cam grind was different to how it should have been according to the model stamp. Not misground just mis-stamped Sad
New one now in waiting for me to fit everything back on .
cunningplan
« Reply #378 on: December 07, 2011, 09:04:35 PM »
 Grin Grin Grin
I love Christmas pudding  Roll Eyes
cunningplan
« Reply #379 on: December 07, 2011, 09:14:13 PM »
I know a well known racer who put in a new cam and lost nearly a couple of seconds, found out they had given him the wrong cam grind. With Fords, they have two cam set ups, one swaps the firing order on two cylinders, at least when he found out, all he had to do was change two plug leads. (I'm hoping I've got the right one)
cunningplan
« Reply #380 on: December 08, 2011, 12:12:16 AM »
Here are some photos taken today, including the new driver for 2028.
First the engine with all the leads (Waiting for separators) the throttle cable and the Harley oil filled oil pressure gauge.
(The rocker covers have been sand blasted and etched primered)
http://www.cunningplan.net/engine4.jpg
The Cunning Coupe
http://www.cunningplan.net/engine5.jpg
The Cunning Coupe
http://www.cunningplan.net/engine6.jpg
The Cunning Coupe
Now some of the new gear linkage.
http://www.cunningplan.net/gearlink4.jpg
The Cunning Coupe
http://www.cunningplan.net/gearlink5.jpg
The Cunning Coupe
http://www.cunningplan.net/gearlink6.jpg
The Cunning Coupe
http://www.cunningplan.net/gearlink7.jpg
The Cunning Coupe
The new welded steering link and a view from the cockpit (And yes there will be more bolts before it goes out)
http://www.cunningplan.net/steering26.jpg
The Cunning Coupe
http://www.cunningplan.net/steering27.jpg
The Cunning Coupe
http://www.cunningplan.net/steering28.jpg
The Cunning Coupe
And my new grandson Rory
http://www.cunningplan.net/rory.jpg
The Cunning Coupe
I am going to spend most of the day down the garage Saturday. I will be doing the wiring, seeing what pipe work I need for the brakes so I can order it and whatever else I can finish.
« Reply #381 on: December 08, 2011, 11:09:03 AM »
Awww- GrandDad, the drag racer -what a lovely example you set for younger generations Tony!  Grin
Car's really looking great now. Wish I knew what half that stuff did.
wizzkitt
« Reply #382 on: December 08, 2011, 12:40:26 PM »
Isssss lovely. How long before you can put Rory to work on it? Start 'em young... Smiley
« Reply #383 on: December 08, 2011, 03:25:52 PM »
Rory the racecar driver -isn't that a kids' TV show?
I really like that lime green etch primer colour!
« Reply #384 on: December 08, 2011, 06:18:18 PM »
thats looking good.
the rocker cover on my morris was green etch primer!!!!
« Reply #385 on: December 09, 2011, 04:30:21 PM »
thats looking fantastic  and its nice to se gramps with the young one just make shure you train him up well  he is racings future
cunningplan
« Reply #386 on: December 10, 2011, 08:35:35 PM »
I am hoping that my granddaughter (10) or grandson (Cool will have a go in the junior dragster up the track next year, Rory though has got a few years to go yet. Anyway, what I done today.
I spent 8 hours down the garage today and not got a lot to show for it. The first thing I had to sort out was the back axle, when we pushed to car into the garage last night, we (As in the youngster who works down there) found diff oil on the insides of each tyre. When I took them off this morning I found the problem. Ages ago, I put the callipers from the back to the front to make it look neater, to do this you have to undo 6 bolts each side and swing the plates around and swap the callipers over from one side the other, Looks like I only put a couple of the bolts back in to see if I liked it or not and forgot about it. The oil was coming out of one of the missing bolt holes.
They are right behind and hidden by the disc's so I had to strip the whole lot back off, find and fit all the bolts and stick it back together again.
This done I looked to see if I could do anything with the throttle, it had a very long travel. Part of the linkage was a little chrome bracket, this did not fit my carb, I took it off and put it away. When looking for the axle bolts I found it and thought it might do the job to extend the bottom of the pedal. I took the pedal off and drilled an extra hole and bolted on the bracket, bolted it all back on, changed the angle of the cable and it works great.
http://www.cunningplan.net/throttle8.jpg
The Cunning Coupe
http://www.cunningplan.net/throttle9.jpg
The Cunning Coupe
The main job for the day was the wiring; I had already wired the main switch panel so I fitted it to where it’s going to sit. (I had to swap the ignition and fuel pump switches over as the ign switch looked to easy to knock off, I will be putting labels over the old ones.)
http://www.cunningplan.net/wiring1.jpg
The Cunning Coupe
When I came home last weekend I thought I had put all of my parts into the van, but I forgot the master switch and solenoid, as I know where they are going to fit, it was not a problem. All the wires are sleeved and heat shrink at each end, I bought a plug kit so everything can be taken out of needed without stripping all the wiring.
http://www.cunningplan.net/wiring2.jpg
The Cunning Coupe
That is about it for now, we are off to Eastbourne next weekend and with Christmas and the New Year, I won’t be doing much on the car until well into the New Year.
cunningplan
« Reply #387 on: December 20, 2011, 10:37:18 PM »
The car is wrapped up for Christmas and I can't see me doing anything before the new year.
So I would like to wish you all a Merry Christmas and a Happy New Year from Linda and myself.
« Reply #388 on: December 20, 2011, 11:25:23 PM »
You've wrapped it up for Christmas? That's a hell of a pressie!
Merry Manky Christmas to you too.  Wink
cunningplan
« Reply #389 on: December 23, 2011, 03:34:09 PM »
Yesterday I decided to order the brake fittings, so I phoned Fay at Speedflow. It’s hard sometimes to explain exactly what you need, so I drew a diagram and worked it out. Not only did Fay understand what I needed but they were sitting in the garage this morning.
As I only knew the exact size of the two pipes from the callipers to the axle plate, I knocked these up this morning, I have also put the next set of fittings (From the axle plate to the T connector) at the end of the hose, I will have to wait until I can get the car back into the garage before I know how long these are going to be so I can cut them to size and fit the other ends. It’s quiet down the garage at the moment so it might be next week sometime.
I would like to say a big thankyou to Fay at Speedflow for her prompt service and will be getting all my fuel fittings from her when the tank has been made.
http://www.cunningplan.net/brake9.jpg
The Cunning Coupe
« Last Edit: December 23, 2011, 07:23:09 PM by cunningplan » Logged
