April 08, 2026, 07:19:51 PM *
Pages: 1 ... 20 21 [22] 23 24 ... 36
Author Topic: The Cunning Coupe  (Read 167125 times)
« Reply #315 on: October 22, 2011, 06:33:04 PM »
Tony What are you going to make the tank out of.
cunningplan
« Reply #316 on: October 22, 2011, 07:04:10 PM »
Alloy John
« Reply #317 on: October 22, 2011, 07:15:32 PM »
Alloy John, gotta new motor?
Who supplied the kingpin kit Tony? I need to replace the bearings in mine too, but the Custom Car magazine article didn't say where it came from. How much if you don't mind me asking? Did you hand ream them, as per the article? By coincidence, Ol Skool Rodz magazine ran a feature on this last month too.
« Last Edit: November 02, 2011, 10:34:17 PM by Manky Monkey » Logged
cunningplan
« Reply #318 on: October 22, 2011, 07:57:17 PM »
I got them from Pops Place at (Whisper) 72quid  Cry
I have asked John (Hunter) if he had a reamer, just needs to know what size, yes you do it by hand, bit at a time and creep up to size.
« Reply #319 on: October 22, 2011, 10:32:38 PM »
Not much creeping going on up here Shocked
So how big is it then Wink
cunningplan
« Reply #320 on: October 26, 2011, 07:44:50 PM »
I will measure the old pin and let you know. (Real money or mm?)
Been a busy couple of days, between and after work, down the garage and in the house, I have been tweaking the headers and finished and trial fitted the "buck?" for the tank. I had already set up one side of the headers, so with the wood I had left for doing the tank, I drilled it to fit the flanges and bolded the part finished one and the flange for the other each side of it.
I cut down the other pipes and fitted them into the flange and tacked them in place, I used the wood to line them both up. The only problem I had was that one side was lower than the other, I tried twisting the whole 4 pipes together but couldn’t, so cut the straps and did them one at a time until both side matched, then I tacked the pipes back together on the ends. Now when the sit on the floor upside down there is no rock.
http://www.cunningplan.net/headers26.jpg
The Cunning Coupe
http://www.cunningplan.net/headers27.jpg
The Cunning Coupe
http://www.cunningplan.net/headers28.jpg
The Cunning Coupe
Last night after work using a steamer to bend some hardboard over the tank frame and tacked it in place, I had a few problems with the main one that I should had used thicker wood, as it kept on splitting. Anyway, I managed to finish it and took it down the garage this morning to try it in the frame. I put a couple of straps around the bottom frame and sat it on top. I am very pleased with the way it looks and sits. It will have just a rounded front, but the back will be like a funnel, tapering down with the fuel feed at the end like the original on Crescent Coupe.
We will use the buck to bend the alloy around, so I have wrapped it in gaffer tape to help make it smoother (Hides the nail heads).
http://www.cunningplan.net/fueltank4.jpg
The Cunning Coupe
http://www.cunningplan.net/fueltank5.jpg
The Cunning Coupe
http://www.cunningplan.net/fueltank6.jpg
The Cunning Coupe
Next week I am taking the headers up my friends where I will be brazing the tubes into the flanges. This is what the company who I bought the headers recommend, it helps stop them cracking at the flange. I can’t weld the silencers on until I trial fit the headers, then I can tack them in place and then fully weld them.
« Reply #321 on: October 26, 2011, 11:08:40 PM »
Some luvverly pipework there Tony.
cunningplan
« Reply #322 on: November 01, 2011, 08:15:12 PM »
Last weekend, Steve gave me back the finished wing and supports. The supports are all the same length and it relies on the bottom mounts to give the right angle.
Today I went into work early trial fitted it. Its mounted on the end of the torsion bar mount plates.
I have looked at the photos of Crescent Coupe and it looks not far off the same, but as the front axle is down Steve's, I think it looks too high/odd, will have to wait until I get the axle back on and then see what it looks like.
http://www.cunningplan.net/wing13.jpg
The Cunning Coupe
http://www.cunningplan.net/wing14.jpg
The Cunning Coupe
http://www.cunningplan.net/wing15.jpg
The Cunning Coupe
Tomorrow evening I am going straight up my mate Moony's to weld up the headers, so hopefully another update and photos tomorrow.
cunningplan
« Reply #323 on: November 02, 2011, 09:54:30 PM »
Here I am not long back from Moony's and I hope all my measurements are correct as the headers are now fully welded (Brazed) As I brazed the pipes into the flanges, I gas welded the rest together.
http://www.cunningplan.net/headers29.jpg
The Cunning Coupe
http://www.cunningplan.net/headers30.jpg
The Cunning Coupe
http://www.cunningplan.net/headers31.jpg
The Cunning Coupe
Will be trying them on Saturday.
If they don't fit, I can always be
SUPER HEADER
http://www.cunningplan.net/headers32.jpg
The Cunning Coupe
« Reply #324 on: November 02, 2011, 10:33:36 PM »
The rocketeer.  Cool
« Reply #325 on: November 02, 2011, 10:36:03 PM »
DAVID BOWIE,S rocket man Cheesy Cheesy Cheesy
« Reply #326 on: November 03, 2011, 10:47:50 AM »
The name is.....Bond..........Basildon Bond.................................... Grin Grin Grin Grin
« Reply #327 on: November 03, 2011, 10:49:43 AM »
More Like Brook. Grin Grin
« Last Edit: November 03, 2011, 10:51:23 AM by hunter » Logged
« Reply #328 on: November 03, 2011, 08:57:53 PM »
More like a PG Tips monkey.
« Reply #329 on: November 03, 2011, 09:27:42 PM »
Damn!!!! I wish I`d thought of that one  Roll Eyes Roll Eyes Roll Eyes Roll Eyes
