April 08, 2026, 02:16:04 PM *
Pages: 1 ... 13 14 [15] 16 17 ... 36
Author Topic: The Cunning Coupe  (Read 166980 times)
« Reply #210 on: April 18, 2011, 08:22:52 AM »
That's hee-uge Tony! Nicely made though.
« Reply #211 on: April 18, 2011, 04:12:00 PM »
Big enough for a charger maybe?
Tis a beast n half Tone, do the front wheels locate in the slots at the front end?
cunningplan
« Reply #212 on: April 18, 2011, 05:31:05 PM »
Charger, it would flattern it  Wink the new car should weight under 750 kgs, Charger about 2 tonne  Roll Eyes
Yes, (If I have measured right) they will help keep the wheels straight when loading & unloading and as I said there will be stops at the ends (Like you get on some bike trailers) to locate the wheel at the ends.
Blackpig
« Reply #213 on: April 18, 2011, 08:20:46 PM »
Nice trailer, shame about the car Kiss
cunningplan
« Reply #214 on: April 18, 2011, 09:17:13 PM »
If I put a single wheel on the front would that be OK  Roll Eyes
cunningplan
« Reply #215 on: April 25, 2011, 05:51:18 PM »
The two ends are now joined and its home (well down the garage)
I set off early Sat morning with the trailer (Empty) and found that nice and stable. I got to the Shed at 9 just as Steve turned up to find the jig and chassis was already set up.
http://www.cunningplan.net/oddball.jpg
The Cunning Coupe
(Dragster or Monster Truck?)
I was the first thing we were going to do, but Scottie was there the day before picking up his repaired parts, (The Pop which crashed the weekend before at Shakey, lost a front wheel (Including hub, disc & calliper) and it hit the front of Scottie & Gina's Coupe damaging the steering link, split wishbone and chassis.) and they had set it all up.
We knew it was going to be too short but Steve had a piece of 4 x 2 ready, we welded that in and set up the torsion bar into the front set for the 162 wheel base.
http://www.cunningplan.net/chassis46.jpg
The Cunning Coupe
After a few bends and a few hours (Like about 20) and it was sitting on its own four wheels and was pushed outside.
http://www.cunningplan.net/chassis61.jpg
The Cunning Coupe
http://www.cunningplan.net/chassis64.jpg
The Cunning Coupe
Then after a few shots it was time to fit the body
http://www.cunningplan.net/chassis65.jpg
The Cunning Coupe
http://www.cunningplan.net/chassis70.jpg
The Cunning Coupe
Here’s a drivers view
http://www.cunningplan.net/chassis71.jpg
The Cunning Coupe
And one of the happy driver
http://www.cunningplan.net/chassis74.jpg
The Cunning Coupe
It was time to try the trailer. It took a little time but we managed to get the car on (If only I thought about lifting the body before loading it  Sad (it would have saved use quite a bit of time))
http://www.cunningplan.net/trailer11.jpg
The Cunning Coupe
And the van & trailer
http://www.cunningplan.net/trailer10.jpg
The Cunning Coupe
Once loaded it was time to make my way home, again it towed and handled great. I still have the fittings for the front wheels to sit in, but these and the eyes for the straps can't be fitted until the car is completely finished and we can set the nose weight.
I will be doing bits what I can up the garage like cleaning and etching the chassis where finished (There are the rear four bar mounts and cross braces, the steering pivot and other small brackets still to be welded on.
Due to track, holidays and family commitments my next visit to darkest Wiltshire will not be until the beginning of June.
I again would like to thank Steve & Lesley for all their help and hospitality, also John Munday for the use of the tube bender. Thanks John.
« Reply #216 on: April 25, 2011, 06:14:43 PM »
WOW! Lovely lookin beast, the car, not the driver  Grin. Another classic leaves Brock`s stable, he knows how to turn them out!
« Reply #217 on: April 25, 2011, 06:51:03 PM »
That's a hell of a machine Tony. Looks beautiful. Can't wait to see it in action.  Grin
cunningplan
« Reply #218 on: April 25, 2011, 07:42:59 PM »
Thanks both, I can't fault Steve's work, unlike mine  Shocked I made one of the cross braces a little short (Will not be wasted as they will fit somewhere else) went and made the same mistake when I made the next one  Cry It's at a angle both ends and I marked up the wrong side  Angry
Did'nt do it again though.
« Reply #219 on: April 25, 2011, 09:37:02 PM »
We won't tell anyone. Honest.  Wink
« Reply #220 on: April 25, 2011, 09:39:52 PM »
Nice job that. Very impressive  Cool
http://www.choppit.co.uk
Al
« Reply #221 on: April 25, 2011, 09:43:54 PM »
you should realy be proud of that
how much of turning circle on that
realy nice be good to see it once it is in all its glory
al
cunningplan
« Reply #222 on: May 01, 2011, 08:11:16 PM »
Thanks for the comments, (Turning circle? at the moment it will be quite good, its not got any lock stops  Wink)
The only real thing that bothered me about the body, was that the rear body lines each side were taken off when the wheel arch's were filled in.
http://www.cunningplan.net/body72.jpg
The Cunning Coupe
So last week it was a trip to B&Q to look for something I could use to make a new one (I had already taken all the cut offs from the body to the local tip) I looked what shaped steel the had and then went and found the wood moldings. I picked up a piece of 21 x 5mm d section for a couple of quid.
I drilled some holes and screwed it on to have a look
http://www.cunningplan.net/body73.jpg
The Cunning Coupe
It looked good so I took it off, mixed up some resin and stuck it back on, gave it a couple of coats of fibreglass, a coat of etch primer.
http://www.cunningplan.net/body76.jpg
The Cunning Coupe
The next day I bought a sander, sanded it down and sprayed in normal primer.
http://www.cunningplan.net/body77.jpg
The Cunning Coupe
http://www.cunningplan.net/body78.jpg
The Cunning Coupe
I have not put any filler on it yet (As I haven't got any yet) but it looks 100% better, all I have to do is the other side.
« Last Edit: May 01, 2011, 08:21:41 PM by cunningplan » Logged
« Reply #223 on: May 01, 2011, 08:45:42 PM »
Details -it's all in the details isn't it. Makes the difference between a nice job & a great job.
« Reply #224 on: May 05, 2011, 02:26:49 PM »
nice looking, i'm not brave enough to pilot one of those!!!
