April 10, 2026, 09:05:40 AM *
Pages: 1 ... 6 7 [8] 9 10 ... 36
Author Topic: The Cunning Coupe  (Read 167800 times)
cunningplan
« Reply #105 on: August 02, 2010, 04:00:16 PM »
Best wishes from me Tony.
Thanks TB, the good news is, I have just got back from seeing mum and shes doing great and will hopefully be fully recovered in a couple of days. I'm going to phone the hospital in the morning and is she is still doing well, I am going home and Linda (Mrs Plan) and Lesley (Daughter) are going to stay for a few more days as they are both on holiday.
gazzagood
« Reply #106 on: August 02, 2010, 05:19:55 PM »
Glad to hear she's on the mend tony.best wishes from me.and mrs good.hope she's back home soon
gaz
PLEASE
cunningplan
« Reply #107 on: August 04, 2010, 09:11:38 PM »
Had these drop through the door tonight (Well brought by Mark (The person who made the spacers)) These go on the front of the 4 bar and fix to the bat wings on the drop tube.
http://www.cunningplan.net/frontaxle26.jpg
The Cunning Coupe
http://www.cunningplan.net/frontaxle27.jpg
The Cunning Coupe
« Reply #108 on: August 05, 2010, 10:11:56 PM »
Them's nice.
cunningplan
« Reply #109 on: August 11, 2010, 05:55:07 PM »
Well the weekend has been and gone and we got as much done as we could. We were hoping to start on the cage and I even took my helmet and neck brace up, but setting up the gearbox and making the motor plate and all the little odds and ends we did not get anywhere near it, but we still go a fair bit done.
When I took the box and other bits up, I also took the shim plate that goes between the engine and box. Steve measured this up and transferred it all onto a bit of 3 mm steel plate, he cut it to fit between the rails and then cut out the two main holes (Crank and starter motor) and drilled for the bell housing bolts.
http://www.cunningplan.net/motorplate2.jpg
The Cunning Coupe
http://www.cunningplan.net/motorplate3.jpg
The Cunning Coupe
While he was doing this, I decided that the callipers on the back axle would be better at the front, this would take the brake pipes out of the way. This did not take long and it looks a lot better for it.
http://www.cunningplan.net/rearaxle13.jpg
The Cunning Coupe
Lesley and I started to make up the seat; we used cardboard and transferred this to the alloy sheet. When marked out, Lesley cut it out with the plasma cutter. We bent this around a gas bottle and fitted it into the chassis. It was cut oversize, so when it was fitting perfect, we marked it and I trimmed it off with a disc cutter.
http://www.cunningplan.net/seat3.jpg
The Cunning Coupe
http://www.cunningplan.net/seat4.jpg
The Cunning Coupe
With the motor plate made, Steve started to make the chassis mounts for it. The bottom ones will also be used to hold the belly pan at the front.  We are going to fit a checker plate floor between the gearbox and rear axle anti rotational bars, so I cut a couple of support bars to go in between. These will also be used to take the back stays for the gearbox mount (Not shown in photo)
http://www.cunningplan.net/enginebox21.jpg
The Cunning Coupe
This was as far as I got, they have been shutting the M4 at Newport overnight for the last few weeks so I had to make a early exit so not to have to take the long detour. Steve and Lesley were still going to finish off a few things before they went home.
For those who have been following the build will know I had to shoot off down to Eastbourne the other weekend, as my mother had be rushed into hospital. While my mother will be out in a couple of days, it has taken a toll on myself and family, I have decided I have to put the build on hold for a while.
The engine and parts have been put away in my son’s garage and will stay for a couple of months, also with events and holidays, I will not be able to go The Shed until the end of October at the earliest. The car is still planned to be out next year, but I don’t think it will be at the beginning.
I would like to say a big "Thank you" Steve & Lesley for not only building the car, but looking after me while I am down in deepest Wiltshire and also when up the track.
My site has been updated (And paid for, for another year) at http://www.cunningplan.net/thefuture.html
« Reply #110 on: August 11, 2010, 07:15:14 PM »
Noone can blame you for making that decision Tony, there are much more important things in life than our respective hobbies. I`m sure i won`t be the only one looking forward to the next phase of your build, however long it takes is irrelevant, it`ll be worth it.
« Reply #111 on: August 11, 2010, 09:27:35 PM »
you gotta look after your mum.
« Reply #112 on: August 16, 2010, 07:51:39 PM »
And yourself as well!  Sensible decision.
cunningplan
« Reply #113 on: August 17, 2010, 07:12:20 AM »
Thanks you lot, I always forget about myself  Embarrassed
Anyway, while I was up the Bulldog bash, Steve & Lesley have been busy with my car. Steve has finished the gearbox mount, the anti rotational device (Stops the axle from turning if the diff seizes) made the axle plates and made and fitted the bottom to the seat
as normal, more on my site at http://www.cunningplan.net/thefuture2.html
« Reply #114 on: August 17, 2010, 09:37:01 PM »
They've certainly been busy bunnies haven't they. Looking fantastic Tony.
cunningplan
« Reply #115 on: August 23, 2010, 08:11:19 PM »
At long last my mum is back home, phoned her last night and she even sounds better than she has done for a while now.
Me, starting to get my head together and do want to get stuck back in, but I also want to take it slow and not get back to where I was the other week. When I get the time, I am going the grind in the valves and after the holes have been drilled and tapped, fit the outer springs.
Just a small undate from The Shed, Steve has finished welding the axle plates and the seat has been finished and fitted.
http://www.cunningplan.net/axlemount5.jpg
The Cunning Coupe
http://www.cunningplan.net/seat10.jpg
The Cunning Coupe
The seat will have padding made by my friend Reg, he done the one in The Plan but after a accident has not done anymore for over 10 years, he said he is going to dig out the sewing machine and give it a go. The plan is to use red flake vinyl (I have only found one place who sell it, does anyone knew of anywhere else?)
More updates coming soon
gazzagood
« Reply #116 on: August 24, 2010, 04:04:28 PM »
glad to hear your mum's much better.. always make's you feel better yourself.great news and keep up the great work.
gaz
PLEASE
« Reply #117 on: August 27, 2010, 06:15:26 PM »
Brought back memories.........
I've got a pic of the Crescent Coupe rail in an early edition of National Drag Racer, don't recall if I ever saw it (grey cells getting old) as only visited Blackbushe in that era (end of the 60's and into the 70's). Certainly don't recall any other similar machines of the period.
I can remember Topolinos being used extensivley for Spedeworth Superstox in the 70's where they took the body and chopped it to fit.
Found this on youtube which may be of interest as it has a couple of 'bodied' rails (plus a fantatsic soundtrack - no music, just engines!)
http://www.youtube.com/watch?v=clGU7V44QRI&feature=related
(if the link doesn't work, search for      CackleFest 2010 with Don Garlits at NHRR   )
cunningplan
« Reply #118 on: September 09, 2010, 09:30:03 PM »
Slow but sure, its still going forward. Over the last couple of days, I have given the heads a quick clean (Pointless doing too much until the rocker stud holes have been drilled and tapped)
The valves have all been ground in by hand, complete gasket set and other bits have been ordered.
http://www.cunningplan.net/heads2.jpg
The Cunning Coupe
also a couple of items dropped through the door today (Well down the garage) The first was the flame retardant Red flake Material. Steve will be cutting out the holes in the seat for the harness, them taking it up the HRDs. Reg said to bring that up with the fabric and he will start making the padding. The other parts are weld on brckets of Dzus fasteners, which included the springs and rivets to hold them.
http://www.cunningplan.net/seat12.jpg
The Cunning Coupe
http://www.cunningplan.net/dzus1.jpg
The Cunning Coupe
More news soon.
Tony, never saw myself, but always loved the way it looked, I hope mine looks as good when its finished, it won't be through lack of trying.
« Reply #119 on: September 14, 2010, 12:24:23 PM »
Lookin' good Tony.
