March 22, 2026, 06:41:45 AM *
Pages: 1 2 3 [4] 5 6 ... 9
Author Topic: Reliant gearbox to VW  (Read 32328 times)
« Reply #45 on: May 02, 2009, 05:13:18 PM »
Just my 2p..............
       The spline on the sliding part of the prop doesnt happen to fit does it?
                  Rod
 Oh and good work there!
reliantman
« Reply #46 on: May 02, 2009, 05:50:46 PM »
I still have some bits left so I could do something. I will look for another shaft anyway.
I should have just tacked the bits and then welded them away from the shaft. I'll know better next time. Embarrassed
reliantman
« Reply #47 on: June 04, 2009, 07:30:00 PM »
I have done a bit more welding while it has been nice, but I am only getting a couple of hours a day as it is just too hot.
Getting there slowly.
« Reply #48 on: June 04, 2009, 07:35:34 PM »
Keep plugging away Doug.  Wink
« Reply #49 on: June 04, 2009, 09:59:12 PM »
As someone said to me recently `you may as well take your time, do it right and how you want it to be`.
Looking good mate, i can foresee a shortage of vw engines once you perfect your adaptation.  Wink
reliantman
« Reply #50 on: June 05, 2009, 06:25:48 AM »
I dunno. I'm still chasing another driveshaft. I have a spare CX500 one which I might have a go at if it does work out.
lunatic
« Reply #51 on: June 05, 2009, 05:51:52 PM »
Ive been watching this with interest, always fancied doing a front engined vw hot rod type thing!  Cool
Our trike had no cooling tinwear on it when we got it, my only tip is to make sure your inlet manifolds are long enough to not transfer the heat to the carbs. Ours used to boil off the fuel from the float chambers!! But your running a single carb on a long manifold, so just ignore my rambling!!
reliantman
« Reply #52 on: June 05, 2009, 07:35:33 PM »
No worry.
I was thinking about two SU carbs, but if the heating prob is that bad I might stay with a single jobbie.
I was looking at the freezing that sometimes happens with long inlets, and as I have to fit an oil cooler anyway, I was looking at getting some copper tube and running it from the engine oil outlet to the cooler, via being wrapped around the carb inlet.
Any idea's?
« Last Edit: June 06, 2009, 05:31:51 PM by reliantman » Logged
lunatic
« Reply #53 on: June 05, 2009, 07:45:47 PM »
I think twin Su's would be good, the manifolds we had were low profile type 3 ones, so only about 3.5" tall, taller ones should be fine. I would be concerned about the inlet iceing up, as it does on a stock lump in a bug and thats out of any direct air flow. I like the idea of using copper hard oil lines spiralled around the inlet, should take the chill off it!
yanto
« Reply #54 on: June 06, 2009, 10:16:13 AM »
i had a mate in atherstone wark that did this with a capri 5 speed box
looks good when done cant wait to see this done Grin
reliantman
« Reply #55 on: June 06, 2009, 11:48:14 AM »
I had a picture on disc of a 1600 VW with Capri box, but I don't know where its gone now. I'm sure I saw it for sale in one of the bike mags a few years back.
reliantman
« Reply #56 on: June 07, 2009, 08:46:31 PM »
I'm going to look at another type1 gearbox tomorrow, and if its knackered I will definitely be having it. Makes a change, eh?  Grin
« Reply #57 on: June 08, 2009, 11:28:50 AM »
I've bought lots of knackered stuff over the years -just didn't know it at the time.
reliantman
« Reply #58 on: June 08, 2009, 07:19:11 PM »
I am now the proud owner of another VW gearbox. Will strip it this week.
« Reply #59 on: June 08, 2009, 10:19:18 PM »
Aha! The game begins once more Watson!
