March 22, 2026, 03:48:54 AM *
Pages: 1 ... 6 7 [8] 9
Author Topic: Reliant gearbox to VW  (Read 32302 times)
« Reply #105 on: October 14, 2009, 03:15:59 PM »
like it mucka Smiley
Plasticpig
« Reply #106 on: October 14, 2009, 03:24:22 PM »
Thanks. Its slow work.
« Reply #107 on: October 14, 2009, 10:28:18 PM »
Impressive piece of steelwork there Doug.
Plasticpig
« Reply #108 on: October 15, 2009, 08:52:43 AM »
Its a bit rough. Needs cleaning up and I am going to weld some captive nuts inside.
Plasticpig
« Reply #109 on: October 18, 2009, 04:16:07 PM »
Today I had a root around in the shed and found enough nuts & bolts to fasten my bellhousing.
I need about twenty high tensile jobbies, but the old ones will do for now.
I spent the rest of the day cutting & filing my 8mm ally plate. It's just resting together in the pic as I have to line the driveshaft up.
« Last Edit: October 18, 2009, 04:33:28 PM by Plasticpig » Logged
« Reply #110 on: October 18, 2009, 04:55:16 PM »
question, having made up the centre adaptor for both boxes to bolt to, why the need for the ali plate?
Plasticpig
« Reply #111 on: October 18, 2009, 05:29:43 PM »
The piggy bellhousing is a bigger diameter than the metalwork. I might have to wiggle the gearbox around to line it up, and I wanted all the space I could get.
Plasticpig
« Reply #112 on: May 07, 2010, 01:06:46 PM »
Its been a while but I have been playing again.
I am having a rethink on my frame as I don't like the shape. Don't like nicking other peoples idea's but I think Andy's frame looks so right.  I have enough tube to make up another frame and am going to have a look.
« Reply #113 on: May 07, 2010, 06:12:21 PM »
that looks cleaner mate, and you can save the Ural box for the piggy bobber  Wink Wink
Plasticpig
« Reply #114 on: May 07, 2010, 07:58:59 PM »
Thanks Shaun.
Mr indecisive, me. Smiley
« Reply #115 on: May 07, 2010, 09:42:45 PM »
More rake, more rake!
Half an inch off the ground with 20 inch over forks!
And hooge Formula 1 tyres!
An' megaphone exhausts!
An' one o' them soopercharger things!
-top trike designer, me.  Grin
« Reply #116 on: May 07, 2010, 11:02:46 PM »
Mr. M. the change in tablets hasn't helped then?........
« Reply #117 on: May 08, 2010, 07:31:22 AM »
 Tongue
Plasticpig
« Reply #118 on: May 14, 2010, 04:56:51 PM »
I have been having a play with the bender and some tube.
No pics as it is just an exercise to see how a Mankey-style will look with a VW lump in it. If it works I will get some proper tube and make a real frame.
« Reply #119 on: May 14, 2010, 09:07:33 PM »
Let's have a look Doug.
