March 20, 2026, 08:33:00 AM *
Pages: 1 ... 51 52 [53] 54 55 ... 65
Author Topic: RODS build........  (Read 324719 times)
« Reply #780 on: May 19, 2012, 09:08:59 PM »
Tow ball covers -that's a great idea!
andyrennison
« Reply #781 on: May 19, 2012, 09:27:51 PM »
....and who was Soc(k) ratese? Some philosopher geezer?
At the end of the day , He is heard to say "I stink, therefore I am"
steven brock
« Reply #782 on: May 19, 2012, 09:42:48 PM »
The oil cap.. What have you used ? Yes a Jinlun 125 panniers Smiley
one arm bandit
« Reply #783 on: May 19, 2012, 10:14:44 PM »
Its a piece of flexy gas tube for big industrial set ups. Had a long piece of it,but decided not to keep the rest. Realise now I should have,I was so stupid to throw it out!
 Someone on here (Steve Brock I think) gave me a link to some cheap panniers,that look good.My ones took days to make,and as usual with this one off malarkey as soon as theyre done you can see an improvement you should have incorporated!
 What oil pressure is yours making Luke?
fifer enlightened me on this as i asked the same ?    he said between 15-30 idle 50-70ish running
mines between 15-20 at idle up to 55-60 holding at constant revs, havnt had a good fast run since if fitted it, harder to read at idle she vibrates the needle a tad Cheesy
whats your making different gauges mite differ readings but interesting as we both had a new engine hidden by an old block/cylinder head our reading shouldnt be to different Wink
fifer
« Reply #784 on: May 19, 2012, 11:14:04 PM »
Oil pressure will vary even on a rebuilt engine  Sad  due to the fact that the oil pressure relief valve is normally never looked at on a rebuild .
Also depends on whether you have a much older engine with the separate ball , spring  and seat .
These were often replced by the newer one piece cartridge type .
However , the success of the newer oil pressure relief valve was often dependant on how the bush/seat was removed from the block .
Sometimes the block bore was scored and this let oil past the sealing " O " ring on the newer cartridge oil pressure relief valve ,
On most of the engines used where the newer cartridge oil pressure relief valve was fitted as standard it is possible to nick the very thin sealing " O " ring on insertion of the cartridge .
Slight wear/tension on the internal cartridge spring also comes into play between different cartidges .
Tickover differences of 50 to 100 revs can also alter the reading .
If you have 40 to 50 psi at tickover keep a close eye on the reading at higher revs  as you might blow the connecting plastic tubes off {  if fitted }
Personally I do not fit the oil pressure gauge to any of my Reliants due to the chance that the tubes might blow and you loose the oil pressure .
I go by the electrical switch putting the light out .
Right , I am away to bed now to dream of the Torrey Canyon  Grin Grin .
« Reply #785 on: May 20, 2012, 10:22:19 AM »
Thanks to Fifer and all.
 I thought you had asked about oil pressure,but couldnt find the post Luke!
  So............ after making a new cover plate for the petrol pump hole this morning( The first one I made was about 2mm stainless and kept weeping oil). The studs arent central to the plate and I think the plate was twisted and wouldnt sit flat.Now Ive carved a lump of 6 mm aly plate to fit,and instead of a normal gasket and hermetite,Ive used instant gasket.All that hacksawing on a big lump of aly plate soon got the family roused at 8.30 this morning!
  Just noticed the exhaust tail pipe is a bit sooty(I'll go sweep that off!) Did I really say that ..here we go again !Anyways,Im going to have a read up on it and then go out and fiddle with the mixture now
              Rod
Ooooh ! Just realised Ive got to warm the engine to do this,so an excuse to go out for a blatt!
« Last Edit: May 20, 2012, 10:48:07 AM by ROD » Logged
one arm bandit
« Reply #786 on: May 20, 2012, 10:42:34 AM »
my exhaust is full of soot from the blow up, i was going to take the whole system off and jet wash it, mainly in mine  think its the dried oil as that goes sooty,
« Reply #787 on: May 20, 2012, 10:44:29 AM »
The oil cap is an old flip cap bike one Ive had for around 30 years. It came off a aly bike tank. Unscrewed at the neck. I made an adaptor for it to fit the Reliant oil cap,then blocked the breather hole in the top of the Relaint one,and drilled a new hole in the side.It doesnt work as a flip cap anymore,just comes off complete with the Relaint one sort of partially inside it.
trev
« Reply #788 on: May 20, 2012, 01:26:42 PM »
Back on track.......
 Heres the panniers I made,now mounted........
 Lids hinged at the front with a prop fitted inside to hold them open,and locks fitted to secure them.
 Ive already got them loaded with stuff!
http://i956.photobucket.com/albums/ae49/HJody92/daddd.jpg
RODS build........
And heres the water temp and oil pressure gauges in progress.....
 Used two pods to mount the gauges in.(tow ball covers !)
 Used a modified brake banjo to fix the bottom end of oil pipe to the 't' piece .The tubing is stainless covered plastic brake tube,seems to be the same id as the oil pipe from memory. Could be wrong,but I guessed that I would be making more than 40/50 psi on tick over? Possibly low due to restriction of the banjo fitting and/or pipe,which looks neat,but may not be the right thing for an oil gauge?
http://i956.photobucket.com/albums/ae49/HJody92/535156_226808084088439_100002777480836_282599_37203636_n.jpg
RODS build........
                                                 that looks really tidy rod,proper job.
« Reply #789 on: May 20, 2012, 03:23:18 PM »
Thanks Trev.
« Reply #790 on: May 27, 2012, 06:40:00 PM »
The trike rode well to Trikefest and back,no major probs. Cos Im running in the engine,kept to a steady 40/45 mph and a couple of blasts up to 50mph. The main problem arising from the journey (apart from the appalingly bumpy road between Mildenhall and Littleport! Grin)was the rear seat space( depth). I found myself moving too far forward on the front seat to accomodate, as we went over bumps SWMBO tended to move/slip forward on the seat . I think it needs some work. So Ive removed the rear seat , tank and rack,and re mounted the tank about 3" further to the rear. The seat and rack will all move the same amount backward,this should give more room to the rear passenger,and I'll also tilt the seat squab a bit lower at the rear.  Im also going to build 2 small arm rests either side ,and make them height adjustable. The wider gap between the front/rear seats will accomodate a upside down 'U' shape for a front seat backrest/come grab rail for the passenger,with a built in storage area. Im going to make this adjustable to be able to tilt it slightly back and forth to get the best position for me ,as well as the pillion passenger.
  Another problem that was evident was the 'floorboards' ,they need to be wider for the passenger,so this week I'll extend them and get them TIG'd together.Trying to get all this done by the end of the week,cos if the weather holds we may have a couple of days meandering round the Kent or Essex coast.
« Last Edit: May 27, 2012, 06:46:55 PM by ROD » Logged
fifer
« Reply #791 on: May 27, 2012, 09:06:02 PM »
Rod , I am glad that you are finally getting out and about and reaping the fruits of your labour  ; enjoy Smiley
« Reply #792 on: May 27, 2012, 10:04:29 PM »
Down to the fine adjustments now then Rod. I once saw a car seat headrest used as a trike backrest -height adjustable, weather proof, (it was one of those rigid plastic ones with the open centre, maybe Metro), & suprisingly comfortable.
Time to start clocking up those miles of smiles.  Grin
« Reply #793 on: May 28, 2012, 06:27:40 AM »
Thanks Pete.
Head rest is a good idea,but not enuf room.Now maybe if I.....then I .........NO NO NO! Grin
 Got to get all refinements sorted or else"they" wont come out with me!
 Re doing this rear end is like going back to the build stages...but this time I know when its done I can just flick that switch and ride it!
« Reply #794 on: May 28, 2012, 08:24:11 AM »
your point being?
