April 17, 2026, 01:08:42 PM *
Pages: 1 ... 35 36 [37] 38 39 ... 65
Author Topic: RODS build........  (Read 330728 times)
« Reply #540 on: January 15, 2012, 10:44:16 PM »
Flap's orange Reliant trike melted the points a couple of times until we realised the problem, but only on long runs.
Hardtails -love 'em or hate 'em! The ride's a little, erm, interesting. More dumper truck than Rolls Royce. Get used to it kid  Grin
I run standard pressure in the front tyre, (about 35psi), & just 15 in the rears. Any more & it tends to get skittery. That softens the ride a little bit, but it's kinda a series of small bumps.
The heaviness of the steering depends on the rake of the front end. My trikes are normally around 45 degrees -makes 'em quite stable at speed, but as you say, a little heavy at low speed.
It probably seems a little odd to start with, but you soon get used to it. Personally I like the basicness of hardtails & find they give more feedback of the road conditions. Rigid is more fun!
RODeo
« Reply #541 on: January 16, 2012, 03:11:50 PM »
Electronic from Simonbbc plus coil ,now ordered!
RODeo
« Reply #542 on: January 21, 2012, 04:49:33 PM »
Heres the rack /backrest Im building in progress...painted it first coat,then decided to add to it and alter it!..
RODeo
« Reply #543 on: January 26, 2012, 07:26:17 PM »
Designed and bent up a very small rack for a tool roll behind the number plate,and made a tool pouch from leather today. Amazing how much time it took to come up with something for a few tools,not to mention the amount of times I removed and replaced the b****y numberplate mount to get it right!.Pics soon.
dobber
« Reply #544 on: January 26, 2012, 09:56:21 PM »
becomes addictive fella, cant leave em alone.
        can i have it in 20 Min's?
RODeo
« Reply #545 on: January 28, 2012, 04:19:46 PM »
Went out today for a first proper ride. Was a bit apprehensive after breaking down 2 miles away from home,due to points ,a week or so ago,even took my AA card and a charged up phone with me just in case! But WOW! what a difference the elec ign has made! Runs nice. I could have stayed out for hours,just cruising around locally! A bit difficult to get used to the gearchanges,and a couple of times I held the traffic up ,cos I couldnt remember what gear it was in ,and stalled it as I pulled away.But I stayed calm and sorted it.Even stalled it right outside the local bike shop  Roll Eyes Roll Eyes.
 Something about this biking lark ya know..my local Heine Gericke shop was really helpful when I asked about probs with my crash helmet,not even a hint of "wot? you dont know how to dothat"  All bike people seem friendly.Looking forward to more riding out as the weather gets better.
zakboy
« Reply #546 on: January 28, 2012, 04:35:38 PM »
Think most folk are a bit apprehensive first few rides rod i think once you have confidence in the trikes reliability it will be plane sailing and you will get on her and not give braking down a second thought,i went for a good blast out yesterday it was cold on the old hands though
RODeo
« Reply #547 on: January 28, 2012, 04:42:34 PM »
I had gloves and loads of layers on,and didnt feel the cold. Maybe thats because I was concentrating so much on the riding! Now Im home ,we've got the heating on and Im b****y freezing! I agree about the reliability thing. When I build a car I take it out for a local 2 block run then back home to check it out,then a bit further,gradually increasing my radius as time goes on.
« Last Edit: January 28, 2012, 04:46:03 PM by RODeo » Logged
steve brock
« Reply #548 on: January 28, 2012, 06:54:15 PM »
How easy was it to replace the points? Thinking about that myself Smiley
« Reply #549 on: January 28, 2012, 07:24:27 PM »
Congratulations Rod -fun ain't it!  Grin
RODeo
« Reply #550 on: January 28, 2012, 07:31:13 PM »
Replacing the points with elec ign was easy. I followed fifers write up. I didnt remove the dizzy (and therefore its basic position) to do it,so I think that made it easy.Theoretically it shouldnt take more than a couple of hours to do tops,but I routed the extra wire required ,which meant re-doing part of the loom,and also I fitted and made a clip on cap to protect the top of the new coil from water.  This took time. But skates on here has had probs.
        Rod
« Reply #551 on: January 29, 2012, 12:29:45 AM »
That would be one of the kits to convert the standard coil .
as per http://www.simonbbc.com/bundle-deals/ignition-kit-bundles/45d-electronic-ignition-kit-standard-coil-to-match
Easiest way is to get a complete new electronic distributor from Simonbbc rather than just the bits to convert .
This gives you the choice of either
http://www.simonbbc.com/distributors/4cyl-standard-electronic/45d-electronic-distributor-powermax-reliant
Or complete with coil
http://www.simonbbc.com/bundle-deals/standard-distributor-coil/45d-reliant-sports-electronic-distributor-and-lucas-coil-dlb105
Note that when I came to fit my new distributor that I had to file the bit off the distributor to get it to fit into the hole in the block  Shocked
The quality of the casting was not good and the cap was crap , but once I filed the dizzy body and replaced the cap with a Lucas brass insert one , then it ran Ok .
The best situation if it was in a standard Reliant car is to retain the original distributor because that is set up for the vehicle and fit the electronic bits to it .
However , having said that , if the original distributor is worn then your timing with the electronic bits added is also not going to be perfect due to the wear .
If you have enough carrying capacity then Buy a complete distributor kit and store your old coil and distributor on the trike . Then it is just a 2 minute job to drop in by removing the one bolt from the dizzy clamp to engine , disconnecting the wires from the dizzy , discnnecting the vauum tube and dropping the points dizzy back in , reconnect and check timing and Bob,s yer Uncle .
If you have tuned the engine and fitted a different exhaust system then the brand new dizzy route is the way I would go .
PS . I removed the electronic dizzy after a couple of weeks cos I was bored with it and refitted the points dizzy  Grin Grin Grin
steve brock
« Reply #552 on: January 29, 2012, 01:13:25 AM »
Thanks chaps urm I'm running cbr600 carbs and my own made stainless sort of flowed exhaust, runs ok but just thinking ahead .:-)
« Reply #553 on: January 30, 2012, 07:10:55 PM »
Glad it's all getting sorted Rod
Pleased for you.  Grin
http://www.choppit.co.uk
RODeo
« Reply #554 on: January 30, 2012, 07:53:30 PM »
Thanks Iain. Already thinking about the next one! This time a morganesque car type... 2 wheels at the front /single rear wheel drive from a bike engine .
