February 19, 2026, 10:46:46 AM *
Pages: 1 [2]
Author Topic: making cables  (Read 7296 times)
peanut
« Reply #15 on: February 06, 2009, 11:16:46 AM »
I like the tip for cutting outers with a disc and a vice, but I bought a pair of cable-cutters very cheaply at a cycle sale and only ever use them for this job. There is a company in Wombwell (or Cudworth) that organise these one-day cycle sales in sports centres around the North, usually on a Sunday. They are always worth a look for cheap lubricant and cleaner, interesting handlebars etc
klogan45
« Reply #16 on: November 06, 2009, 08:39:20 PM »
Well, here we go again its stoopid question time Grin Grin Grin Grin
What sort of solder should I use? Is it that stuff that plumbers use or that electrical stuff!
Are these solders basically the same or are they totally different. I believe that the plumbers solder has a higher melting point. If not I'm sure someone with more knowledge will tell me........please.
I've just fitted a set of higher bars on the virago 535 and need longer cables.
Thanks
Regards
K
« Reply #17 on: November 06, 2009, 09:03:00 PM »
`standard` solder will be 60/40, thats 60% lead to 40% tin and will be fine, other stuff is available, silver solder for example, which has roughly 2% silver content, this does create a stronger joint but you will find it more or less impossable to use with standard type soldering irons as they just aren`t hot enough.
klogan45
« Reply #18 on: November 06, 2009, 09:27:26 PM »
Thanks Tbone, I'm going to get some nipples.......OOOOH eerrrrrr Missus (can we still call them that in these PC days?) and have a go at this soldering malarky.
Regards
K
Pages: 1 [2]
