April 08, 2026, 07:40:54 AM
Trike Tech
Springer Reliant axle to Radius arm mounts.
Topic: Springer Reliant axle to Radius arm mounts. (Read 1893 times)
November 06, 2008, 10:09:13 PM »
Since my recent radius arm disaster on my mono-shock Honda trike, I've decided to modify the radius arm to axle mounts for my current trike project, based on a 750 Virago, pics below. These should rely less on the welds fixing them to the axle tubes, and act in a "towing" mode, or at least thats the intention! the side "fish" plates,one either side, are welded in place once the bracket is finally positioned on the axle tube, hopefully an improvement, Morrag
Re: Springer Reliant axle to Radius arm mounts.
November 06, 2008, 10:16:56 PM »
Impressive. Just out of interest, how did you form the curve & 90 degree bend?
November 06, 2008, 10:24:54 PM »
Cheated,well sort off, machined a piece of tube to correct bore to suit the Reliants 2"-ish axle tubes, and cut it in half, lengthwise. Full welded the riight angled prefabed angle piece extention, drilling to suit radius arm end plates first.......now my dark secret is revealed Mr.MM!! Morrag
November 06, 2008, 10:55:09 PM »
Sensible way of doing it. Looks rather spiffing.
