December 23, 2025, 01:33:15 PM *
Pages: 1 [2] 3 4 ... 15
Author Topic: tony b,s trike build  (Read 45535 times)
« Reply #15 on: November 02, 2008, 11:01:18 AM »
 Grin muppet  Grin
tony b
« Reply #16 on: November 02, 2008, 04:11:06 PM »
har har har de har
tony b
« Reply #17 on: November 02, 2008, 04:15:01 PM »
went to the scrap yard today.got meself a pair of vw golf callipers and carriers,and also 8 studs and nuts for my diffs.for the total sum of ...........£10,took his arm off at the hip.
cleaned up the carriers and striped the callipers to give them a good clean.
question.
how the heck do i get the piston back in?.
« Reply #18 on: November 02, 2008, 04:32:01 PM »
10 quid?! That's a bargain mate. If he's got any more, might be worth grabbing them while you can.
Don't try & push the piston straight in Tone -it's on a screw thread. Turn it clockwise as you push it in. The pistons are operated by hydraulic pressure for normal braking, being pushed out by the fluid, but sit against a plate that's screwed out when you haul the handbrake on. That satisfies the requirement that the handbrake be mechanically operated & not part of the hydraulic system.
Here's a useful step by step guide to overhauling them:
Caliper overhaul
« Last Edit: November 02, 2008, 07:40:09 PM by Manky Monkey » Logged
tony b
« Reply #19 on: November 02, 2008, 05:28:43 PM »
i need to get 2 new gaitors for the calliper piston.im having problems gettin me pics on.
tony b
« Reply #20 on: November 02, 2008, 06:00:23 PM »
when i try to put pics on it says my file is too large,HELP.
Shriva
« Reply #21 on: November 02, 2008, 07:06:29 PM »
resize them,
Can do it with any image program.. even "paint" that comes with any windows PC..
Open in paint, then click "image" then resize. Try 50%, then save.
Then upload them here..
« Reply #22 on: November 02, 2008, 07:44:42 PM »
Try these guys for rebuild kits
Bigg Red calipers
tony b
« Reply #23 on: November 02, 2008, 11:46:39 PM »
kgfi
tony b
« Reply #24 on: November 02, 2008, 11:47:40 PM »
ha sussed it ,dont know what i did but i did it ,
« Reply #25 on: November 03, 2008, 12:27:50 AM »
Comfy looking ride!  Grin
tony b
« Reply #26 on: November 04, 2008, 06:06:41 PM »
been working on setting out my frame today,got it all square and set up,deciding which front to put on .
welded the engine mounts on and braced the frame at the headstock and behind the box.
ill be putting the back end on in the morning,found some pipe on a frame for holding wire which fit inside my frame tubes and also have the exact bend i need for using when i put the pipe from my axel to the frame ,,,,,,,,,,,result,these frames are thrown away on an almost daily basis.they chuck them into me dads scrap skip.
will put some pics on tonight.
tony.
tony b
« Reply #27 on: November 04, 2008, 11:39:29 PM »
ok time to put pics on aff the parts i have so far.
the build begins
tony b
« Reply #28 on: November 04, 2008, 11:51:21 PM »
cleaned my engine and box
tony b
« Reply #29 on: November 04, 2008, 11:54:29 PM »
got some callipers,they need a good clean yet.
