April 08, 2026, 01:57:10 PM *
Author Topic: putting cables & brake pipes throw frame  (Read 1981 times)
col
« on: October 28, 2008, 05:33:43 PM »
what is the do & don'ts to putting cables & brake pipes throw the frame
E.g. where to place the holes so the frame is not weakaned
 col Smiley
harley gazz
« Reply #1 on: October 28, 2008, 05:42:04 PM »
methinks mankster is ya man fer that jobby, as he likes to hide his bits n bobs in the frame  Wink
arc eye tha noo
« Reply #2 on: October 28, 2008, 06:43:22 PM »
 Smiley
Never really thought about it. Our frames aren't riddled with holes. maybe 4 or 5 in total, spread around the frame. The heavy gauge ERW tube we use has a wall thickness of nearly 4mm, so providing the holes aren't excessively big, I wouldn't have thought you'd have a problem. I keep any around the headstock a couple of inches away from the joints, as it's the most stressed part of the frame, but otherwise it's just common sense really. The SVA guys will want you to fit rubber grommets or plastic spiral wrap around the holes to prevent chaffing of the wires or cables & if you run copper brake pipe inside the frame, sleeve it in something to stop it rattling against the inside of the tube or it'll drive you nuts!  Tongue
col
« Reply #3 on: October 29, 2008, 06:34:40 PM »
That will be 6 holes in total the down tubes is 33.5 mm x 3.5 mm and top tubes is 50mm x3.5
Was going to sleeve cables & pipes
Thanks for the advice
col    Grin
