April 27, 2024, 11:31:38 AM
General Tech
Basic headstock
Topic: Basic headstock (Read 2855 times)
Basic headstock
October 06, 2008, 05:27:50 PM »
Heres a basic headstock diagram. The cups have to be made to suit the bearing size (in this case 25 x 47 x15) and can then be welded either end of the steel tube.The tube length measurement has vanished but it should say 105mm.
tony b
Re: Basic headstock
October 06, 2008, 07:20:32 PM »
can you make me one pleeeeeeeeeeeeeeeeeeze,how much,ok ill have one then.
Re: Basic headstock
October 06, 2008, 07:42:40 PM »
The idea is to do it yourself.......with a little help from your friends on this very forum.
Have you got your Yokes/ steering pin sorted out yet?
Can you get your hands on some 45mm ish thick walled pipe?
tony b
Re: Basic headstock
October 07, 2008, 06:01:03 PM »
yes got complete front end yes i can get some pipe,how do i make the bearing cups
Re: Basic headstock
October 07, 2008, 06:18:35 PM »
you dont, i`ll pm you the name of a man on here that can tho.
Last Edit: October 07, 2008, 06:28:07 PM by tbone
Dicky
No refund's
Re: Basic headstock
October 07, 2008, 07:55:56 PM »
tbone, excuse my ignorance.
47mm - outside diameter of bearing
15mm - depth of bearing
25mm - inside diameter of bearing??
So I said to God, "If this is it (life), you can keep it."
And God said, "Just be glad you got the heart by-passes in time.
I don,t normally give refunds".
Re: Basic headstock
Reply #6 on:
October 07, 2008, 08:22:12 PM »
Quote from: Dicky on October 07, 2008, 07:55:56 PM
correct
. But as i say, if your thinking of doing this you need the measurements of the bearings you will be using on the stem, and the cups are made to suit.
