May 05, 2026, 02:01:59 AM *
Author Topic: New Engine  (Read 5314 times)
reliantman
« on: July 13, 2008, 09:19:00 AM »
Hi All.
I have gone over to the dark side, (no I'm not gay) but have bought a VW instead of a piggy lump.
I swapped some scrap box section for a Fiat 126 engine, decided I could'nt use it and put it on fleabay.
From the proceeds I bought this locally.
reliantman
« Reply #1 on: July 13, 2008, 02:40:08 PM »
With all the cooling tin removed.
« Reply #2 on: July 13, 2008, 06:44:44 PM »
Ooh, a Swedish style V Dub. I quite like those. Is that the old Cossack frame?
reliantman
« Reply #3 on: July 13, 2008, 07:14:20 PM »
Yes it is. I have had to lay off for a few months because of skintness, but I'm getting back on track now.
It won't be a full on Swede, just a budget version with Rascal axle, but I will probably use the reliant gearbox as the frame is so short.
andbolt0
« Reply #4 on: July 13, 2008, 08:50:22 PM »
a 5 speed box would be a good update no idea what would fit though good luck with it.  skintness seem everyone has a bit of that ,worse tha the summer colds(man flu)
reliantman
« Reply #5 on: July 13, 2008, 09:34:55 PM »
Well I would like to fit a Bedford rascal box, which would match the axle, but I'm not sure if there is room for it in the frame. Pity as I had two in my garden but my mrs made me bin them.
What I will probably do is to find a bell housing off a VW T25 gearbox, which unbolts, and sandwich it with a piggy box.
« Reply #6 on: July 14, 2008, 12:22:05 PM »
be interesting to see if that actually matches up so that it works Smiley most peeps use 2 type 1 vw gearboxes, good luck m8e Grin i'll watch with interest Smiley
reliantman
« Reply #7 on: July 14, 2008, 02:41:52 PM »
I have looked at that, but I dunno if two boxes would fit in the frame.
« Reply #8 on: July 14, 2008, 02:52:24 PM »
try this m8 will have the frame dimensions on it at least so u can compare
http://www.britchopper.co.uk/forum/viewtopic.php?t=6937
reliantman
« Reply #9 on: July 14, 2008, 05:52:47 PM »
Thanks VB.
My mate has just bought a Beetle to Swede, and I am going to take dimensions from his bits.
reliantman
« Reply #10 on: July 17, 2008, 12:44:14 PM »
Result!!!!!!!
My luck must be changing.
A bloke near me has two VW vans outside his house and I went around to ask for some advice.
It turns out he had a bellhousing in his spare van and I grabbed it for fifteen quid.
I brought it back expecting to have to make an adaptor, as I have read on the net that the later boxes will not fit a Type1 block. Tried it against the flywheel and it slid straight on, holes as well!
« Last Edit: July 17, 2008, 02:25:27 PM by reliantman » Logged
reliantman
« Reply #11 on: July 17, 2008, 01:50:02 PM »
With Reliant box.
« Reply #12 on: July 17, 2008, 02:15:03 PM »
That's an interesting combination.
Is the output shaft on the V Dub bellhousing offset towards the top? How will you mate that up to the Reliant box?
reliantman
« Reply #13 on: July 17, 2008, 02:36:13 PM »
Well, thats the next job. The two input & output jobbies are lined up, but I am not quite sure how it is going to work for now.
I have also tried the piggy box further back, up against the diff flange, and could possibly have a long shaft with two U/J's from the VW clutch to the Reliant input end.
I would like to use a U/J between the diff flange and gearbox, but have been told it would be better if there was a rubber donut in there.
Any suggestions?
« Last Edit: July 17, 2008, 02:41:52 PM by reliantman » Logged
reliantman
« Reply #14 on: July 18, 2008, 12:46:25 PM »
Rascal/Reliant U/J.
