Hi can anyone HELP
I'm building a trike using a 535 Virago as a doner.I've used the engine, loom and all the origional ancilleries.
During the rebuild and test stage (Prior to restarting the engine) when the ignition and kill switch are both on the fuel pump would run for 5 seconds aprox' as it should.
But now I'm in a possition to start it the pump don't run???
I've tested the pump and with a direct 12 volt supply that runs but whe connected through the loom it don't work
Any ideas can any one shed any light???
