firstly, i no, we covered all this before! but having seen andy mention `pipe center` in his frame build thread, i thought i`d check them out. They are a franchise and have branches nationwide.
The web site is slow and hard to use, unless you know your Part no`s. I was also advised not to order from the web site, but contact my local branch directly as in most cases they could offer a better price!
This is not an indorsment of thier products, but a guide to thier pipe sizes.
Pipes are identified by "nominal" or "trade" names that are loosely related to the actual dimensions. For instance, a 2-inch steel pipe has an inside diameter of about 2 1/8 inches and an outside diameter of about 2 5/8 inches.
It is common to identify pipes by inches using NPS or "Nominal Pipe Size". The metric equivalent is called DN or "diametre nominel". The metric designations conform to International Standards Organization (ISO) usage and apply to all plumbing, natural gas, heating oil, and miscellaneous piping used in buildings.
Diameter Nominal nominal Pipe Size
- DN - - NPS -
(mm) (inches)
6 1/8
8 1/4
10 3/8
15 1/2
20 3/4
25 1
32 1 1/4
40 1 1/2
50 2
Part No. nominal ID OD Description
L11021 25mm 33.7mm M of red med p/e tube en10255 25mm
L11022 32mm 42.4mm M of red med p/e tube en10255 32mm
L11023 40mm 48.3mm M of red med p/e tube en10255 40mm
L11024 50mm 60.3mm M of red med p/e tube en10255 50mm
L11041 25mm 33.7mm M of red hvy p/e tube en10255 25mm
L11042 32mm 42.4mm M of red hvy p/e tube en10255 32mm
L11043 40mm 48.3mm M of red hvy p/e tube en10255 40mm
L11044 50mm 60.3mm M of red hvy p/e tube en10255 50mm
Medium (med) pipe has a wall thickness of 3.2mm
Heavy (hvy) pipe has a wall thickness of 4.5mm
The OD remains constant between med and hvy, so the ID will not be as stated, it is a nominal size.
Minimum qty of sale is 6.5 meters although its priced per meter.
EN10255 is the red coated stuff that has now replaced BS1387
P/E = Plain Ended
S/S = Screw Section: one end male threaded, one end female threaded
E/E =
?? (was mentioned on web site but no one i spoke to knew wot it meant)
And if you ask nicely, sometimes they will cut it up to managable lengths for free!
Information sourced from the web site and a very nice lass in bristol so if its wrong, blame them.
