June 09, 2026, 06:44:20 AM *
Author Topic: a lesson in pipe?????  (Read 6488 times)
« on: June 03, 2008, 01:25:29 PM »
firstly, i no, we covered all this before! but having seen andy mention `pipe center` in his frame build thread, i thought i`d check them out. They are a franchise and have branches nationwide.
The web site is slow and hard to use, unless you know your Part no`s. I was also advised not to order from the web site, but contact my local branch directly as in most cases they could offer a better price!
This is not an indorsment of thier products, but a guide to thier pipe sizes.
Pipes are identified by "nominal" or "trade" names that are loosely related to the actual dimensions. For instance, a 2-inch steel pipe has an inside diameter of about 2 1/8 inches and an outside diameter of about 2 5/8 inches.
It is common to identify pipes by inches using NPS or "Nominal Pipe Size". The metric equivalent is called DN or "diametre nominel". The metric designations conform to International Standards Organization (ISO) usage and apply to all plumbing, natural gas, heating oil, and miscellaneous piping used in buildings.
Diameter Nominal         nominal Pipe Size
 - DN -                        - NPS -
   (mm)                      (inches)
6                               1/8
8                               1/4
10                             3/8
15                             1/2
20                             3/4
25                             1
32                             1 1/4
40                             1 1/2
50                             2
Part No.      nominal ID        OD                      Description
L11021            25mm          33.7mm               M of red med p/e tube en10255 25mm
L11022            32mm          42.4mm               M of red med p/e tube en10255 32mm
L11023            40mm          48.3mm               M of red med p/e tube en10255 40mm
L11024            50mm          60.3mm               M of red med p/e tube en10255 50mm
L11041            25mm          33.7mm               M of red hvy p/e tube en10255 25mm
L11042            32mm          42.4mm               M of red hvy p/e tube en10255 32mm
L11043            40mm          48.3mm               M of red hvy p/e tube en10255 40mm
L11044            50mm          60.3mm               M of red hvy p/e tube en10255 50mm
Medium (med) pipe has a wall thickness of 3.2mm
Heavy (hvy) pipe has a wall thickness of   4.5mm
The OD remains constant between med and hvy, so the ID will not be as stated, it is a nominal size.
Minimum qty of sale is 6.5 meters although its priced per meter.
EN10255 is the red coated stuff that has now replaced BS1387
P/E = Plain Ended
S/S = Screw Section:  one end male threaded, one end female threaded
E/E = Huh?? (was mentioned on web site but no one i spoke to knew wot it meant)
And if you ask nicely, sometimes they will cut it up to managable lengths for free!
Information sourced from the web site and a very nice lass in bristol so if its wrong, blame them.
« Last Edit: June 03, 2008, 05:46:19 PM by tbone » Logged
« Reply #1 on: June 03, 2008, 02:03:42 PM »
my last stuff i got from newport"localish to me" CDS and was dear but my body is broken up enough Smiley plus the engine is a tad heavy Grin
« Reply #2 on: June 03, 2008, 02:32:12 PM »
Cold Drawn Seamless, Top end quality for your average fabricator, used by pro`s and rich welshmen too  Grin
« Reply #3 on: June 03, 2008, 02:51:53 PM »
pmsl it was the engine's fault not me Grin
brock
« Reply #4 on: June 03, 2008, 06:32:44 PM »
   E/E would normally be end to end and is used to define the length that a pipe needs to be cut to, to fit between fittings. The fittings are shown on drawings as being C/C (centre to centre) so the distance from centre to mating face has to be deducted to arrive at pipe length, sometimes an additional allowance has to be added back on to allow for threading, occasionally this is not added and the cussing begins, much to the merriment of the carpenters who pride themselves on their abilities with tape and rule.
madron
« Reply #5 on: June 03, 2008, 07:16:40 PM »
aye and to confuse us even more pipe is different to tube
« Reply #6 on: June 03, 2008, 10:26:30 PM »
Brock's one of those annoyingly talented people who can work just as easily in wood as metal. He served an apprenticeship as an engineer before switching trades to take up carpentry & joinery, (what's the difference?). He can make stuff fit without bashing it wiv a 'ammer, so is officially a clever git.
Thanks for the info TBone. Appreciate the research.  Wink
« Reply #7 on: June 04, 2008, 04:31:59 AM »
I thought he sounded like somebody who knew what they were on about, is he on the right forum? Grin
"Thanks for the info TBone. Appreciate the research.  "
guess who had a quiet day yesterday  Grin
« Last Edit: June 04, 2008, 04:53:42 AM by tbone » Logged
« Reply #8 on: June 04, 2008, 04:21:51 PM »
Brock's my big brother. Unfortunately the cleverness doesn't run in the family. I'll have to settle for being the cute one.  Tongue
« Reply #9 on: March 10, 2011, 08:43:33 PM »
Shameless plug for one of my early posts
In response to a p.m, i`m just bumping this  Wink
Al
« Reply #10 on: March 10, 2011, 09:06:34 PM »
thanks tbone for putting this into english chears
al
« Reply #11 on: March 11, 2011, 01:40:45 PM »
Come on Andy you know what that one is:
Carpenter lays Carpents
Joiner joins stuff together Smiley
My old man was a carpenter, cabinetmaker and wheelright by trade. I always think of anythink to do with wood as being carpentry, good job my old chap aint around to see me type it though eh? Wink
« Reply #12 on: March 11, 2011, 08:28:46 PM »
I always wanted to be a cabinet maker.  The diffrence really is a bit like the difference between a house-painter and a painter of pictures!
Carpenter does things like rafters and doors and windows - a cabinet maker makes fine furniture.
Nearest I ever came was building a sledge for my children with skills my dad taught me.  Must have done it right cos my grandchildren use it now - isn't that great?   Cheesy
« Reply #13 on: March 11, 2011, 10:11:14 PM »
I don`t get on with wood very well, measure 5, 10, 15 times and I`ll still cut it wrong. If it doesn`t melt when you put a flame to it, I have no idea what to do with it. Cheesy Cheesy Cheesy Cheesy
