May 04, 2026, 01:45:29 PM *
Pages: 1 ... 13 14 [15] 16 17 ... 85
Author Topic: Tazet's 69 Dodge Charger.  (Read 594352 times)
« Reply #210 on: June 30, 2008, 06:25:59 PM »
Must be the drugs as I've never said it  Grin
Will have the box all ready for you.  Grin So when you coming over?
lunatic
« Reply #211 on: June 30, 2008, 06:28:32 PM »
Dunno! I think Ill pop round sometime after the weekend as the bus and the MGB I have in are going by then. Ill get sketching some ideas then!  Cool
« Reply #212 on: June 30, 2008, 06:30:29 PM »
Oky doky  Grin
« Reply #213 on: June 30, 2008, 07:00:55 PM »
Bugger, I'd better get painting then.
XL-erate
« Reply #214 on: June 30, 2008, 08:11:01 PM »
Some rebuild kit prices from Summit Racing, usually one of the lower prices over here:
http://store.summitracing.com/egnsearch.asp?N=700+4294925232+4294870280+400298+4294908110+115+4294840053
The re-ring kit is less than $175. If your engine just needs a honing, rings and a home valve job that would almost do it. I'd add main bearings though. Maybe mic the cylinders and also see what kind of ridge cylinders have, make an estimate from there?
Have you guys figured out if it's a smallblock or bigblock transmission? If it's smallblock a strong 318 would surprise you with the right gears! Or give fun performance and decent mileage. No, a 318 won't roast the tires going sideways at 50 mph, but they can be real quick. 318-340-360 interchangeable in a car set up for smallblock. 360's can pull 350-375 hp with the right build, 400+ if it's a 360 Magnum!
« Reply #215 on: June 30, 2008, 09:14:18 PM »
Chears for that and no we've not found out if the transmission is small or big block yet.
XL-erate
« Reply #216 on: July 01, 2008, 07:47:38 AM »
I'll try to attach pic of transmission bellhousings, difference between small block and big block. Big block is on left, smallblock on right. Note difference in where starter boss is, big block at center, smallblock below center.
Will try another pic showing tranny pan outline. 904/A500 smallblock is square with a corner cut off. Big block is irregular outline.
XL-erate
« Reply #217 on: July 01, 2008, 07:53:24 AM »
Here's a pic of tranny pan outline. A-904 and A-500 are smallblock. A-518 is the heavy duty 727 transmission with overdrive added, 4 speeds, but it fits a smallblock. Unlikely you'd have an A-518 so if pan is irregular then it's probably a big block 727 3 speed auto. Bellhousing outline and starter location will nail down which it is.
« Last Edit: October 09, 2012, 08:12:31 PM by Manky Monkey » Logged
XL-erate
« Reply #218 on: July 01, 2008, 08:00:28 AM »
There are American military bases in several countries. The Dodge trucks used on those bases are full of great parts for your project and often the trucks are sold off pretty cheap. Can be a real goldmine for you if there's any bases around. Also those bases may have servicemen's cars around that they didn't want to ship back stateside.
« Reply #219 on: July 01, 2008, 06:43:15 PM »
Chears again for that and will have a word with my step dad's brother as he will know where the American bases are around here.
« Reply #220 on: July 01, 2008, 07:03:13 PM »
Used to be a huge airbase at RAF, (?) Greenham Common, Newbury, Berks when I lived there as a teenager. They flew F111 fighters & Hercules fuel transporters over the town all day long & kept Cruise missiles on the base. The peace protesters had a permanent camp outside the main gate -they even had their benefit cheques delivered there by the Post Office. It's all gone now & the base is a commercial busines park. The protesters stayed on for years afterwards & only left when the council agreed to build a memorial garden where the camp had been.
Loads of huge square pick up trucks around the town in those days. No idea what manufacturer they were from. You could spot the servicemen a mile off in the main street cos they stood literally head & shoulders above the locals & had that typically all American clean cut look about them, even off duty.
« Last Edit: July 01, 2008, 07:20:37 PM by Manky Monkey » Logged
« Reply #221 on: July 01, 2008, 07:11:36 PM »
Well you never know Taz, plenty of time to come up with another engine!
I was bidding on a PAS rack on Ebay for the Maestro, already lost 2 cos they went too high.  Posted on the Maestro club forum to make sure I wasn't bidding against another member and someone on there will shortly have one for sale cheaper than the Ebay one, result!
Always wise to stick to your limit.
XL-erate
« Reply #222 on: July 02, 2008, 07:05:11 AM »
Hope it opens more options for you kids. Majority of American Military trucks around the world were Dodge. With Charger originally being smallblock and unknown if big block transmision, engine mounts, exhaust and all the rest has been installed, might be far cheaper to nick a used truck and pirate the whole drivetrain.
Almost everything, engine/carb/ignition, transmission, rear axle & springs, power steering & brakes and so many other parts swap right over from a 60's to 90's Dodge truck to the '69 car!
« Reply #223 on: July 02, 2008, 11:14:00 AM »
saw this on ebay:
engine
« Reply #224 on: July 02, 2008, 11:17:22 AM »
another
engine 2
