March 29, 2026, 03:30:46 PM *
Author Topic: Wheels and tyres  (Read 2491 times)
hairy monsta
« on: February 17, 2008, 10:29:13 PM »
Now please please please correct me if I'm wrong here but as I understand things I have to keep the overall wheel/tyre diameter to somewhere near the original Reliant figures if i want a balance between acceleration and a reasonable top end so depending which you start with the tyre width/profile would limit wheel diameter and vise versa
Some mornings its just not worth chewing through the leather straps!
« Reply #1 on: February 17, 2008, 10:51:49 PM »
Check out the tyre size calculator in the Motors, 3 wheels, trike tech section of the main site.
It'll help you decide what size you need. The profile of the tyre is a percentage of it's width -so the height of a 70 profile tyre is 70 percent of it's width. Therefore, 2 tyres, the same profile, but different widths, will be different heights.
As a rough guide, we've found an overall wheel/tyre height of around 24 inches gives good acceleration in the first 3 gears, with 4th gear becoming a sort of overdrive for motorway cruising. From 0 - 60, our trikes will actually outrun a lot of road cars. They'll cruise at 70 -75 quite happily & slowly wind up to a top speed of around 85 -90 if you have enough road, but are happiest blatting around A roads at about 60 - 65.
hairy monsta
« Reply #2 on: February 18, 2008, 02:00:29 PM »
Thanks for the info Manky.
 I got the tyre width/profile bit, its more the effects of increasing/reducing overall wheel/tyre diameter will have and at what sort of rate??
 If I'm understanding it correctly a smaller wheel/tyre combo will increase acceleration whilst reducing top speed and a larger overall diameter would reduce acceleration and increase top speed.
 So i guess what I really need to know is what noticeable difference each extra inch makes. (Too easy don't do it Grin) and at what point it would become an issue. Any ideas folks?
« Reply #3 on: February 18, 2008, 09:28:46 PM »
Cheap innuendo's always worth the effort I find  Grin Oh, alright then.  Sad
Yup, spot on with the effects of wheel size. As for the exact point at which it becomes a problem -really not sure, as we've found a size that works & stuck with it. Maybe this will help. Maybe not.
Tyre size/diff ratio calculator thingy
Anyone else got an opinion or first hand experience?
pagan
Ride like yer stole it...
« Reply #4 on: February 18, 2008, 10:23:22 PM »
I run these 185/80R14 91T TL HANKOOK K715 (14" rims 100pcd 4 stud) on me xj9 reliant axle trike with approx overall wheel height of 25", works great good acceleration through gears 1-4 (v quick from the lights). Not over reving n sits @ 70-80 all day...like MM says 24"+ give n take any 'finger nails'...works well...Triker tried n tested... Cool
Cheers The Pagan
The Pagan
