April 30, 2026, 03:30:32 PM
HotRod Tech
for manky monkey
Topic: for manky monkey (Read 5545 times)
twolanes
PRO ET/571
for manky monkey
February 04, 2008, 10:28:59 PM »
just seen this lot on the NSRA site, under for sale
1954 Ford Pop bodyshell & chassis, HA front end, No rear end, doors, panels
Log book - + Reg 3 letters 3 numbers £350.00
Ford 289 cu in Smallblock for rebuild, block, crank, heads, rods etc £250.00
Ford 302 cu in Smallblock for rebuild, block, crank, heads etc. No rods £200.00
1 x Rover 3.5 V8 with auto box - Sdi £150.00
1 x Rover 3.5 V8 - P6 (high comp) £100.00
1 x Rover 3.5 V8 - Sdi £100.00
Pair 81/2 x 15 Wolfrace slot mags, MGB pattern centre caps & nuts £85.00
Pair 11/4 SU�s on �A� series manifold £20.00
Bluepoint 20 ton Portapower £150.00
Large single phase compressor £200.00
Dunlop wheel alignment gauge £100.00
Draper Arc welder - new £50.00
Aquaplane alloy cylinder head for 100E Ford £150.00
Aquaplane inlet manifold with twin SU�s (need rebuilding)for 100E Ford £100.00
Aquaplane exhaust manifold for 100E Ford £50.00
Stock Pop rear axle £40.00
Stock Pop front suspension £50.00
4 x Stock Pop gearbox�s £40.00 each
Bellamy or LMB 1950/60�s Independent front suspension conversion for Ford Pop
with hydraulic front brake conversion £250.00
Bellamy or LMB 1950/60�s �Anti roll� rear spring & panhard rod for Ford Pop £100.00
2 x Webasto sliding canvas sunroofs, new £100.00 each
For sale for a mate who is losing his interest in the hobby.
Please contact Alan Humphries on 07870 525441
Re: for manky monkey
February 05, 2008, 09:52:53 AM »
nice one twolanes. I might be in need of some of that stuff myself
February 05, 2008, 02:47:18 PM »
Not really much I need at the moment, but I immediately thought of you Shaun! An interesting shopping list.
