March 29, 2026, 12:25:29 AM *
Author Topic: trike batterrie  (Read 3446 times)
« on: January 23, 2008, 09:09:37 PM »
whats the most ptactical batterie to fit on a reliant trike where space is limited
« Reply #1 on: January 23, 2008, 09:17:01 PM »
All ours use a 14 amp hour bike battery, as used on mid sized Jap bikes, (mine was from an XS850 Yam).
They'll take the charge from the Reliant alternator, (same model as used on Austin Minis & early LandRovers), & run the motor quite happily -don't forget to use a ballast resistor or you'll fry the points. We know cos we've done it several times! If you leave the trike sat in your shed unused for a month or so though, you'll probably have to give it a quick jumpstart the first time you drag it out into the daylight again.
« Reply #2 on: January 23, 2008, 09:34:06 PM »
um do you wire it up as 12v or 6v...i now stupid Q but someones got too
« Reply #3 on: January 23, 2008, 09:42:09 PM »
Very noble of you to volunteer for the dumb questions job VB  Wink
12 volt. Later Reliants actually run on about 9 volts, only using a full 12 for starting. The ballast resistor costs about 15 quid & acts as a heat sink to get rid of the surplus, so needs to be mounted in the airflow to keep it cool. Without it the plastic body of the points melts -doesn't it Mr Flap!
« Last Edit: January 23, 2008, 09:47:27 PM by Manky Monkey » Logged
« Reply #4 on: January 25, 2008, 05:59:34 AM »
2 new 18ah battery,s ordered from county battery,s at nottingham(found the peeps in shops on evil bay)
£8.75 each +post  not bad me thinks
« Reply #5 on: January 25, 2008, 07:24:32 AM »
sounds ok ..bet postage would be a killer though Smiley
« Reply #6 on: January 25, 2008, 01:44:16 PM »
Coo, that's cheap! They're usually shipped dry, so you might find they're not supplying the acid with them. Could cost you time & money trying to get them filled.
Flap & I bought new batteries each at the BMF show in Peterborough. Cost 20 quid each.
dracken1
« Reply #7 on: January 26, 2008, 06:54:57 PM »
beware batteries are like motorcycles. you have your honda, kawasaki, suzuki, yamaha etc.
then you have jinlun boatian kinroad.
they not all created equal Sad
not trying to sell you any as mine are more expensive than the ones quoted above Wink
« Last Edit: January 26, 2008, 06:59:07 PM by dracken1 » Logged
« Reply #8 on: January 28, 2008, 11:18:21 PM »
battery,s arrived at 8.30 am this morning  their genuine exide  as promised  i just cant beleive it  for the price of £8.75 each  i only ordered them on friday
                                                well chuffed
                                                           mike
« Reply #9 on: January 28, 2008, 11:57:50 PM »
Sounds like you got a bargain mate. Well done.  Wink
dracken1
« Reply #10 on: January 29, 2008, 12:32:12 AM »
must be some sort of deal or clearance coz when i check thier site prices mine are cheaper  Cheesy
