May 05, 2026, 06:37:47 AM *
Pages: 1 [2] 3 4 ... 15
Author Topic: mouse's new trike project :-)  (Read 57809 times)
« Reply #15 on: January 05, 2008, 03:56:13 PM »
ok guys you asked for it  Grin Grin Grin
Mousy Boy :-) AKA Mick Smiley
« Reply #16 on: January 05, 2008, 04:04:54 PM »
Yup, carry on babbling mate. It's just the sort of info that people are always asking for.  Wink
What may seem blindingly obvious to you could well be a revelation to someone else so post away Sir!  Smiley
Piccies really are worth a thousand words by the way.
col
« Reply #17 on: January 05, 2008, 05:57:10 PM »
carry on  we are watching  Grin Wink looking good
« Reply #18 on: January 05, 2008, 07:08:34 PM »
I shortened the half shafts measuring and cutting them was a very worrying time  Shocked lol one chance only yikes now me i like to have at least 6 attempts at things  Grin Grin
http://i31.photobucket.com/albums/c355/007mouse/new%20trike/DSC00026.jpg
http://i31.photobucket.com/albums/c355/007mouse/new%20trike/DSC00025.jpg
This is them sleeved with a solid round bar that i bored out to suit the size of the half shafts and belive it or not both half shafts where a differnt size good ole reliant  Grin
onec i had them bored out to the correct size i simply slid the half shafts into the bars which are now tubes.And welded them up with my mates very good oil filled kick ass stick welder lol at 160 amps  Grin fingers crossed its all going to be strong enough
pie
« Reply #19 on: January 05, 2008, 08:51:23 PM »
Mouse, just a bit of info you might find useful, the bloke who did the joining and welding on mine has had plenty of experience doing the same with Escort axles for rally cars and his tried and tested method includes drilling and pinning using engineering dowel then welded in and spun up on the lathe to get it balanced.
Here's a picture of mine so you can see what I mean.
« Reply #20 on: January 05, 2008, 09:17:16 PM »
cool pie  i can add the pins no problem thanks (scuttles off to the workshop to sort it out)  Grin
pie
« Reply #21 on: January 05, 2008, 09:20:11 PM »
Make sure it's ENGINEERING DOWEL though!
« Reply #22 on: January 05, 2008, 09:30:24 PM »
will do m8 i will get some in the week  Grin
« Reply #23 on: January 06, 2008, 09:30:43 AM »
next stage im my axle build
because they axle tubes were broken from my previous screw up  Roll Eyes
errr welding the axle solid to my last trike Shocked not a good idea lol
heres the diff with whats left of the tube
http://i31.photobucket.com/albums/c355/007mouse/new%20trike/diff.jpg
heres the other end  Shocked
http://i31.photobucket.com/albums/c355/007mouse/new%20trike/axletube.jpg
A good lesson to be learned there DONT SOLID WELD A RELAINT AXLE IT DONT LIKE IT
me being a right muppet did it twice hows that for being stupid  Grin Grin two axles knackerd
i know some people weld them and get away with it
this is a mock up of the new tubes and diff in place between the wheels
http://i31.photobucket.com/albums/c355/007mouse/new%20trike/axletubes1.jpg
http://i31.photobucket.com/albums/c355/007mouse/new%20trike/axleloop6.jpg
I internal and external sleeved the remains of the axle tubes with very strong 2" inch ID 5MM wall thick tube a bit OTT but once or should that be twice bitten i ain't taken any chance with another axle breaking i was lucky to survive that last two breaks.
« Last Edit: January 06, 2008, 06:16:43 PM by mouse » Logged
« Reply #24 on: January 06, 2008, 02:53:21 PM »
I'm a Postie, not an engineer, but I always try to stress here -SAFETY FIRST. I'd hate anyone to get injured after following our advice, (& I can't afford the lawsuits!), so always better to over-engineer than chance it. If you're not competent to do the job yourself, find someone who is. We pinned the narrowed axle on Flap's orange trike in exactly the same way.
« Reply #25 on: January 15, 2008, 02:58:31 PM »
Right carrying on from where i left off  Grin
but before i do ****please read**** This is my build if you are going to copy any of my ideas please check and double check that they are going to do the job for you UNDER no circumstance are MANKY MONKEY MOTORS responsible for anything i do or anything i put on this web site .****
Mick aka mouse
Next job i did was to make a loop to go over the axle for added strength the one thing i did want was to be able to split the diff if i had any problems in the future.
so i machined a solid piece of bar to fit the inside of the tube i was using as my loop.
i made the loop then cut it in half and inserted the machineing piece in the ends of the tube which i then drilled and bolted. I then welded the loop to the axle tube all i have to do now is unbolt the two bolts and i can split the diff Grin
http://i31.photobucket.com/albums/c355/007mouse/new%20trike/axleloop1.jpg
http://i31.photobucket.com/albums/c355/007mouse/new%20trike/axleloop4.jpg
http://i31.photobucket.com/albums/c355/007mouse/new%20trike/axleloop2.jpg
blair
it looks bigger in water ! !
« Reply #26 on: January 15, 2008, 03:37:45 PM »
looking good mouse but whats with the disclaimer you don't here them saying things like that on blue peter and belive me toilet tubes can be deadly if you dont do them right  Grin
« Reply #27 on: January 15, 2008, 03:47:47 PM »
I'd just like to point out, MMMotors do not condone the use of toilet tubes as axles.
« Reply #28 on: January 15, 2008, 05:50:24 PM »
Smiley
reliantman
« Reply #29 on: January 15, 2008, 06:25:26 PM »
But they prepared them earlier, off camera. Smiley
