March 30, 2026, 02:26:29 PM *
Pages: 1 [2]
Author Topic: handbrake on mini trike  (Read 8678 times)
klogan45
« Reply #15 on: November 26, 2007, 09:50:42 PM »
Thanks BG and Col. Do the metro discs/hubs and the golf calipers fit on mini running gear, being a bit thick here but don't want to waste money if they don't fit. Also you say that the calipers fit on the original metro mounts, confuzicated again Grin Shocked
Thanks
K
« Last Edit: November 26, 2007, 09:52:59 PM by klogan45 » Logged
lunatic
« Reply #16 on: November 27, 2007, 10:29:43 AM »
Try looking at one of the late model metros. They may have had discs on the rear that you can steal the caliper off. The only model that is likely to have rear discs is the 1.4 gti. The metro discs are the same as mini ones I think. Rover 200s may be the same rear calipers?
« Reply #17 on: November 27, 2007, 12:02:06 PM »
You might find some info here - http://www.austin-rover.co.uk/
It's the Unofficial Austin Rover Web Resource and there's a forum on there.
klogan45
« Reply #18 on: November 27, 2007, 06:15:26 PM »
Thanks lunatic and BG, will follow those suggestions up.
Thanka again
Keith
col
« Reply #19 on: November 27, 2007, 06:45:09 PM »
 try asking herehttp  ://www.minispares.com/Auth/ForumTopics.aspx  Huh
klogan45
« Reply #20 on: November 27, 2007, 09:48:28 PM »
Thanks Col, good site, could spend loads there Grin Shocked Shocked
Regards
Keith
Pages: 1 [2]
