March 30, 2026, 02:34:53 PM
Trike Tech
handbrake on mini trike
Pages:
Topic: handbrake on mini trike (Read 8688 times)
klogan45
Re: handbrake on mini trike
Reply #15 on:
November 26, 2007, 09:50:42 PM »
Thanks BG and Col. Do the metro discs/hubs and the golf calipers fit on mini running gear, being a bit thick here but don't want to waste money if they don't fit. Also you say that the calipers fit on the original metro mounts, confuzicated again
Thanks
K
Last Edit: November 26, 2007, 09:52:59 PM by klogan45
lunatic
Reply #16 on:
November 27, 2007, 10:29:43 AM »
Try looking at one of the late model metros. They may have had discs on the rear that you can steal the caliper off. The only model that is likely to have rear discs is the 1.4 gti. The metro discs are the same as mini ones I think. Rover 200s may be the same rear calipers?
Reply #17 on:
November 27, 2007, 12:02:06 PM »
You might find some info here -
http://www.austin-rover.co.uk/
It's the Unofficial Austin Rover Web Resource and there's a forum on there.
klogan45
Reply #18 on:
November 27, 2007, 06:15:26 PM »
Thanks lunatic and BG, will follow those suggestions up.
Thanka again
Keith
col
Reply #19 on:
November 27, 2007, 06:45:09 PM »
try asking herehttp ://www.minispares.com/Auth/ForumTopics.aspx
klogan45
Reply #20 on:
November 27, 2007, 09:48:28 PM »
Thanks Col, good site, could spend loads there
Regards
Keith
Pages:
