blair
it looks bigger in water ! !
« on: November 16, 2007, 08:26:11 PM » |
i though i should put something onto the pages . it all began with my brothers trike and an urge . i bought a gpz 550 that was in a frame and had most of a wiring loom . after lugging it back to my work i set about trying to get it going which i thought would be tricky a it had been sat in a field for 4 or 5 years but after a lot of swearing it did indeed fire up ( sort o ) it would only fire on 2 cylinders and that was as for as i got with it. now my intention was to build my own frame and put the engine into there but as luck would have it a hardtail z 550 came onto ebay and with a quick cheeky call a deal was made and in no time it was back in my work , and as it goes it too had been sat for several years since last running but had no wiring so i used the loom of of the gpz and by some strange twist of fate it too would only fire on 2 cylinders. as it goes it would spark on all 4 but then after a couple of engine turns it would only fire on cylinders 2 and 3 so we change the cd ignitor but nope that did nothing. so i thought long and hard , then tried a few wires in different configurations but still only 2 cylinders. so i had a brain wave the gpz and the z block were the same block so the timing gear would be the same right ? WRONG they were different in the fact the z had a mechanical advance mechanism and the gpz a electric one but with a quick dremel and hack saw blade i cut some of the webs out of the way and fitted the gpz timing pick ups into the z and wayhay it was fired on all 4 cylinders. and bloody hell i was releaved . below is a couple of photos showing the old timing pick ups and the cut out crank case webs and the new gear form the gpz fitted and good to go
« Last Edit: January 20, 2008, 12:24:09 PM by bummer »
« Reply #1 on: November 16, 2007, 08:54:38 PM » |
brave man im glad it worked out for ya m8
Mousy Boy :-) AKA Mick
Ally
« Reply #2 on: November 16, 2007, 09:42:19 PM » |
blair
« Reply #3 on: November 16, 2007, 09:53:41 PM » |
« Reply #4 on: November 16, 2007, 10:04:09 PM » |
Ally
« Reply #5 on: November 16, 2007, 10:10:27 PM » |
« Reply #6 on: November 18, 2007, 11:36:14 AM » |
keep it up m8 always someone worse off
blair
« Reply #7 on: November 18, 2007, 06:32:22 PM » |
keep what up valleysboy are you talking about my chop or my keyboard?
« Reply #8 on: November 20, 2007, 03:43:28 AM » |
chop i assumed
blair
« Reply #9 on: November 21, 2007, 07:27:06 PM » |
ok id thought id better check cause i was not complaining about my chop although it did almost end up in the skip.
blair
« Reply #10 on: January 20, 2008, 12:10:14 PM » |
thought i should add a little update to my project , since my last post i have built my jig ( plans came from chopper builders hand book) excellent site , set my frame on it and set about loosing the funny bit in the frame i cut the section out and with some pipe that was donated from a friend i let in the new bit , the tube had to be turned town as the frame is 25mm pipe and the nearest stock pipe i could get was 26.5 dia . i also tapered the pipe end to allow for as much weld coverage as possible.
blair
« Reply #12 on: January 20, 2008, 12:18:26 PM » |
blair
« Reply #13 on: January 20, 2008, 12:19:52 PM » |
i tried with the block in to make sure that they lined up as i didnt want to have to cut them back of again
« Reply #14 on: January 20, 2008, 12:35:15 PM » |
Looking good matey.
