December 21, 2025, 07:01:23 PM
Triumph 2005 (old model) creaks!
Pages:
Topic: Triumph 2005 (old model) creaks! (Read 4667 times)
Re: Triumph 2005 (old model) creaks!
Reply #15 on:
September 15, 2007, 06:38:49 PM »
Quote from: BikerGran on September 15, 2007, 06:27:22 PM
I don't believe there's no engineering around, you just haven't found it yet! Ask a mechanic at a local garage workshop
Reply #16 on:
September 15, 2007, 06:43:06 PM »
Wrap the swinging arm in brown paper & send it to Saddlebags. He's got a spark erroder.
Reply #17 on:
September 18, 2007, 01:30:16 PM »
failing that, wrap it in petrol soaked rag and set fire to it, when its burnt away then you can trike it
Reply #18 on:
September 19, 2007, 11:58:22 AM »
Quote from: Manky Monkey on September 15, 2007, 06:43:06 PM
I think if he could get it off to do that the problem would have been solved anyway.......
Nomad
Reply #19 on:
September 25, 2007, 01:56:50 PM »
Today I had my angle grinding frenzy.
Cut the top two legs of the H link.
Ground the remaining ally tubes through and chisled off, leaving the bare shaft seized in the swing arm.
Cut a 29mm section out of it and drifted the outer sheared end inwards and therefore out.
Luckily the blind half retracted easily.
Now I just need the new parts...
If all around you are losing their heads, land your helicopter somewhere else.
Reply #20 on:
September 25, 2007, 03:22:12 PM »
Is that the way Triumph recommend you do it?!
Nomad
Reply #21 on:
September 25, 2007, 04:19:20 PM »
If the guy who designed it was advising, probably yes!
Pages:
