December 21, 2025, 05:21:32 PM *
Author Topic: Triumph 2005 (old model) creaks!  (Read 4652 times)
Nomad
« on: September 12, 2007, 10:45:31 AM »
Aiming to ride the SP3 back to UK to sell it.
All of a sudden its developed a creak from the rear suspension. Sounds like a dry swinging arm pivot. Can't see any lube points.
Anyboby got any ideas or heard of this problem.
Its a old model 2005 with single sided swing arm.
Ta
(the sound when you depress the rear suspension is like a door opening in a Hammer House horror)
Also a few weeks ago the digi speedo started reading a maximum of 25mph, any ideas if this is a known problem before I get involved in changing sensors etc?
If all around you are losing their heads, land your helicopter somewhere else.
« Reply #1 on: September 12, 2007, 12:53:07 PM »
Hiya,
My Speed Triple was a 2000 model -pre digital speedo, so can't help you there I'm afraid. Didn't have any probs with suspension, other than pillions complaining the ride was too hard. Is the shock on rubber bushes? Maybe they just need moistening with a squirt of WD40?
« Reply #2 on: September 12, 2007, 01:41:57 PM »
As Manky said
usually just a drop of oil on the shock bushes and any other bits related to that as they do tend to creak after a while
http://www.choppit.co.uk
retro900
I Love The Blues They Tell My Story
« Reply #3 on: September 12, 2007, 02:16:40 PM »
Not the best idea using wd40, it can cause some rubber to bulge and split.
"Ony Bikers Understand Why Dogs Like To Stick Their Heads Out Of Car Windows"
http://www.bikepics.com/members/retro900/
« Reply #4 on: September 12, 2007, 04:57:36 PM »
Johnsons baby oil?
retro900
« Reply #5 on: September 12, 2007, 05:02:04 PM »
You must be jesting, i've known you nearly thirty years and you're still using that for your little intimate areas.
Try cooking oil or butter, they have no chemical additives.
Nomad
« Reply #6 on: September 12, 2007, 09:41:40 PM »
Thanks, even tried KY but no result.
Apparently needle rollers.
Its only done 13k.
If you put your hand on the linkage you can feel it vibrating as it creaks.
It is binding a fair amount as if you press down on the rear it stays there, and releases as the weight is transferred to the sidestand.
Tomorrow, fabricate hoist system in barn and dismantle, as much as lack of specialist tools allow. Unless you guys can advise more?
« Reply #7 on: September 13, 2007, 05:30:41 AM »
OK I'm not even going to ask  Cheesy
« Reply #8 on: September 13, 2007, 11:57:06 AM »
It's a lubricant isn't it?
« Reply #9 on: September 13, 2007, 01:10:53 PM »
I'm not covering my intimate areas in cooking oil Tony!
Hardtail the Triumph -end of problem.  Grin
Nomad
« Reply #10 on: September 13, 2007, 08:38:15 PM »
If I leave it for another week it will be a hardtail Wink
Cant bloody register the thing here as standard thats why its coming back!
Ask around guys, I will cut my throat on the price of this bike.
£4k with the suspension sorted.
Nomad
« Reply #11 on: September 14, 2007, 09:58:03 PM »
Right, stripped it down today and discovered the linkage thats creakink is the on attached to the ss swing arm. I had to clout it with a newton wrench to get it to move while still on the swinging arm.
Numerous cloutings back and forth have failed to loosen it, along with copious amounts on blood (type WD40)
Recon I have to pull the beariing, can anybody scan/list here/ point to a site where i can see the procedure?
Ta
« Reply #12 on: September 15, 2007, 12:02:04 AM »
It's always a challenge when peeps say that........
There seem to be loads of stuff on the net about various Triumphs having a similar problem - I'm not at all sure what model yours is but this article might be useful...
http://www.richard-halford.co.uk/triumph/major_service.htm
Nomad
« Reply #13 on: September 15, 2007, 05:41:13 PM »
Bobbi, you were spot on with that link, thanks for your effort.
Sadly when using the bolt to withdraw the bearing shaft, the threaded end of the shaft sheared, leaving the majority in the swinging arm. Boy it must be seized.
This is on a 2 year old bike with less the 13k miles. Thanks Trumf for no grease nipples, no wonder you went out of business, it will probably happen again Angry
So here I am in rural France with no engineering industry around, for example spark erosion, inline boring etc. Prolly gonna need a replacement ss swinging arm.
Cnuts!
« Reply #14 on: September 15, 2007, 06:27:22 PM »
I don't believe there's no engineering around, you just haven't found it yet!
