April 01, 2026, 04:18:34 AM *
Author Topic: Piglet  (Read 6728 times)
Adventure Sidecar
Sidecar/Trike Education Program instructor
« on: August 04, 2007, 05:56:18 PM »
I have made a little more progress on my trike project. Unfortunately I miscalculated the ratio of the dif-if I can't find a high speed gearset  for it I will need to start over with a different axle Angry
http://adventuresidecar.com/Piglet/pigletexhaust.jpg
Piglet
If anyone can find specific info for this axle  or the numbers cast in the pumpkin housing I would greatly appreciate it. It looks like a Dana Spicer but lacks any of the ID numbers Dana usually has in the webs. It supposedly came from a 71 HD electric golf cart, which would be good, because there were hi speed gears available for that axle.  I need to get exact model info to find those gears and so far I haven't had any luck coming up with it. Any body recognize this axle or have a 71 HD electric golf car they can photograph for me?
http://adventuresidecar.com/Piglet/axleswngarmwhls.jpg
Piglet
By the way, it seems to handle just fine. No wobbles and reasonable steering effort. It is just too d**n slow!
Vernon
info@adventuresidecar.com
http://adventuresidecar.com/Piglet/piglet.htm
Vernon Wade
sidecar and trike driving lessons and tours
Hood River, Oregon USA
« Reply #1 on: August 04, 2007, 06:17:11 PM »
Hello Vern & welcome to the site! That's some seriously big wheels you got there matey!
Why do the newbies always come up with questions I haven't got a clue how to answer?! Never ever seen a golf cart axle in a trike before. Can anyone help out here?
I'm sure you don't want to, but have you considered changing the wheel/tyre size instead to compensate for the gearing?
Adventure Sidecar
« Reply #2 on: August 04, 2007, 06:48:13 PM »
That's why those wheels are so big! I can't go any bigger without making it look like a John Deere. Besides, those are the largest automotive wheels/tires I could find... anything larger would come from a long haul tractor trailer rig or agricultural equipment!!
Vernon Wade
reliantman
« Reply #3 on: August 04, 2007, 07:32:40 PM »
This one has come up on other forums, and one answer has been to look for a Suzuki SJ413 jeep axle. Could be a lot easier for you to find in the US.
toad
« Reply #4 on: August 04, 2007, 07:35:26 PM »
right thats definatley a dana axle case to get somwhere close to sensible gearing you,ll need to swap the innards for somthing like the dana 44 fitted to the two wheel drive jeep j20 wagoneer! if you open up the back cover and count the teeth on the crown wheel i might be able to help out abit more!
« Reply #5 on: August 04, 2007, 10:42:24 PM »
Don't you just hate clever gits! Hi Toad.  Wink  Knew you'd come through. Well done matey.
Vern, I've only just noticed you're across the pond from us. An extra stiiff upper lipped British welcome Sir.
Adventure Sidecar
« Reply #6 on: August 05, 2007, 02:03:29 AM »
I went to the Dana site and I couldn't find an exact match to this axle. Also the Dana site sez all Dana axles have an ID and model number in the web casting at the back of the pumpkin housing.
I'd LIKE it to be a Dana, but I need to know what model axle it is to get the gears. This axle is also a little weird in that it appears to be upside down but I THINK I have it oriented as the manufacturer intended- there looks to be a vent on top and a drain plug on the bottom as it sits now in my trike. I am told that the gears were probably designed to carry oil up and over...
Overall width is 40" . I don't recall the tooth count but probably wrote it down somewhere when we had the thing apart at the machine shop...
you can see more pix of the build in progress here:
Vernon Wade
Adventure Sidecar
« Reply #7 on: August 05, 2007, 04:56:56 AM »
... if you open up the back cover and count the teeth on the crown wheel i might be able to help out abit more!
The ring gear is stamped 78 5900 and scribed 0.05 7 11 The ring gear has 49 teeth and the pinion 4
http://adventuresidecar.com/Piglet/guts.jpg
Piglet
http://adventuresidecar.com/Piglet/ringgear.jpg
Piglet
« Last Edit: August 05, 2007, 05:00:13 AM by Adventure Sidecar » Logged
Vernon Wade
« Reply #8 on: August 21, 2007, 07:37:33 PM »
hi, this any good to you?
http://www.mankymonkeymotors.co.uk/forum/index.php?topic=83.0
Adventure Sidecar
« Reply #9 on: September 01, 2007, 10:43:28 PM »
I don't think so.
Were you thinking larger tires to compensate for the gears? What I have on there now are probably as large as I want to go for this set up....
Vernon Wade
« Reply #10 on: September 03, 2007, 10:05:20 AM »
does look cool mate, set of motocross forks on the front and you very nearly have a monster trike Grin Grin Grin Grin
