December 17, 2025, 06:15:16 PM *
Pages: 1 ... 45 46 [47] 48 49 ... 63
Author Topic: Tazet's Trike project :)  (Read 292381 times)
« Reply #690 on: February 02, 2009, 12:06:32 AM »
well worth a fiver!  looks to me like you could mount it onto some tube and the tube can follow the bottom line of the seat from back to front, like the `filler` tubes in an earlier pic
« Reply #691 on: February 02, 2009, 12:31:30 AM »
Yup, summat like that TB.  Wink
I also bought a 6" long polished bellmouth from a nice Harley spares chap. If I can persuade Doc to machine us an adaptor, we'll bolt it to the standard Reliant 1 1/4" SU carb. I'll cut up the foam air filter from my own trike & add a disc of foam into the bottom of the bellmouth, then buy myself a new one.
Over the top maybe, but I like the cartoonish quality of it. It'll need to point forward, same as mine. Pointing outwards, it would protrude, (good word), beyond the frame line & cause problems with the sharp, sticky out objects part of the MSVA test. So we'll need to turn the carb through 90 degrees by re-drilling the mounting holes in the manifold, (750 Reliants used Zenith carbs & their manifolds will turn the SU through 90 degrees, which is handy).
« Last Edit: February 02, 2009, 12:33:50 AM by Manky Monkey » Logged
« Reply #692 on: February 02, 2009, 12:44:09 AM »
I found a headlight stone guard for a couple of quid. No mountings on it so I'd have to weld some tabs to the headlight rim, so just as well we plan to strip the chrome off & powder-coat it grey. I thought it might suit the agricultural/industrial look we're going for. Now I can't decide though.
What d'ya think?
« Reply #693 on: February 02, 2009, 12:45:19 AM »
Mr_G
« Reply #694 on: February 02, 2009, 08:15:34 AM »
Looking good, is the mesh to chop the flys up so that they make 4 times as much mess?
« Reply #695 on: February 02, 2009, 08:30:31 AM »
That's a point. Would make it a bugger to clean and I don't do cleaning   Grin
« Reply #696 on: February 02, 2009, 10:18:09 AM »
Taz says she can use the stone guard as a sieve if we don't put it on the trike.
The pointy helmet
« Reply #697 on: February 02, 2009, 04:32:36 PM »
Taz.. To drift off theme a bit... posts 674/675
The trike.
In answer to getting IT out of the conservatory.
It is a softail, so the back axle/swingarms will split from the front end.
It will be "fun" putting this into practise.
I actually read your reply. But the brain was on 21 hours at work a day, setting.
This is a fairly, low ebb, setting...Much like a jelly fishes.
It is on Postie setting now.
....Higher,  before you ask!
« Reply #698 on: February 02, 2009, 06:50:31 PM »
What d'ya think?
go for the grill, looks more purposeful to me and jet washers will knock the flys off  Grin Grin BTW was it cold in the shed Undecided Undecided
« Reply #699 on: February 02, 2009, 06:52:48 PM »
 Grin Yes it was Shaun. How did you guess?  Grin
gpz
« Reply #700 on: February 02, 2009, 11:07:01 PM »
+what i want to know is how you keep that shed so tidy ,
« Reply #701 on: February 03, 2009, 12:14:03 AM »
Very clever Photo-shopping  Wink You can see snow on the floor of the shed in some of those pics.
« Last Edit: February 09, 2009, 12:54:23 AM by Manky Monkey » Logged
The pointy helmet
« Reply #702 on: February 08, 2009, 07:46:00 PM »
No letter trays (ehem!) from work lurking, full of nuts and bolts, Manky?
You'd have to do a good bit of Photoshopping at my gaff!
Looking nice, you two.
Got a deadline, that you are thinking of Tazzer?
« Reply #703 on: February 08, 2009, 08:15:57 PM »
Thanks and no deadline set. We are just doing what we can when we can. We'll be putting it through the new test when it changes so as other people building know what to look out for.
Firery Fred
« Reply #704 on: March 03, 2009, 09:40:12 PM »
Just caught up with this,but going back to the aircraft bits,I remember seeing a bike with a little brass oil cooler that had originally come from some old plane
