December 17, 2025, 08:34:42 AM *
Pages: 1 ... 33 34 [35] 36 37 ... 63
Author Topic: Tazet's Trike project :)  (Read 291939 times)
« Reply #510 on: May 09, 2008, 10:29:50 PM »
« Reply #511 on: May 09, 2008, 10:30:29 PM »
« Reply #512 on: May 09, 2008, 10:31:06 PM »
« Reply #513 on: May 09, 2008, 10:31:46 PM »
« Reply #514 on: May 09, 2008, 10:32:27 PM »
« Reply #515 on: May 09, 2008, 10:33:06 PM »
« Reply #516 on: May 09, 2008, 10:33:46 PM »
« Reply #517 on: May 09, 2008, 10:35:18 PM »
The pipes going to the axle clamps I did all by myself  Grin and the inserts to hold the 2 bits together  Grin
« Reply #518 on: May 09, 2008, 10:36:26 PM »
« Reply #519 on: May 09, 2008, 10:37:13 PM »
« Reply #520 on: May 09, 2008, 10:37:40 PM »
« Reply #521 on: May 09, 2008, 11:27:50 PM »
The hee-uge girder forks were one-offs, specially built for Taz by Mr FLC. They're mated to the rear wheel from a V Max, with the shaft drive hub covered by a chrome "hubcap" from a Harley. The wheel will be powder-coated grey to match the rears, as will the fork legs. Not sure about the chrome cap, maybe black, maybe grey, but chrome's too blingy for the look we're after.
No jigs used for the frame but lots & lots & lots of measuring & extensive use of a spirit level & plumbline. I'd normally tack the headstock in without the forks, but it took me an hour & a half to strip the girders down to slip the headstock tube onto the steering stem & I'm not pulling it all apart again now! I know the forks aren't level in those last shots -we were just trying them in place. They sit at bang on 45 degrees. The kick-ups to the axle clamps were bent seperately & joined to the bottom rails with 4 inch slugs, (sections of tube sliced down their length & squeezed in the vice until they fitted snugly inside the frame tube). We then drilled through the frame & plug-welded the slugs in place, leaving a gap in the joint to run a bead of weld around. The shed floor's a bit wibbly wobbly so we borrowed some sheets of chipboard from Taz's work & shimmed them up until we had a level surface to work on. The trike's wheelbase fits snugly on a standard 8 by 4 foot sheet.
Taz has cut & bent all the tubing herself & will no doubt be trying her hand at MIG welding at some stage.
It doesn't get any more simple & basic than this.
« Last Edit: May 09, 2008, 11:55:47 PM by Manky Monkey » Logged
madron
« Reply #522 on: May 10, 2008, 01:12:09 AM »
ya goin at a crackin pace now be finished for next weekend at this speed
« Reply #523 on: May 10, 2008, 07:32:44 AM »
bleedy hell guys your smokin  Grin its looking good real good
Mousy Boy :-) AKA Mick Smiley
« Reply #524 on: May 10, 2008, 09:17:01 AM »
I wish it was next weekend but it's tomorrow that it's got to be ready for.
