December 18, 2025, 09:22:56 AM *
Pages: 1 ... 19 20 [21] 22 23 ... 63
Author Topic: Tazet's Trike project :)  (Read 292550 times)
« Reply #300 on: February 27, 2008, 11:28:51 PM »
i thought she was showing us the size of..i'll get my coat Smiley
« Last Edit: February 27, 2008, 11:30:48 PM by VALLEYSBOY » Logged
« Reply #301 on: February 27, 2008, 11:30:19 PM »
 Grin I was just demonstrating the easy use with 2 fingers to twist it  Grin
« Reply #302 on: February 27, 2008, 11:31:03 PM »
yeah yeah Smiley
« Reply #303 on: February 27, 2008, 11:39:18 PM »
Stop it you lot!  Tongue
Seriously, not having seen the tap for my trike for a while, we assumed it was meant to be angled. I'll check mine tomorrow. Hopefully we can gently tweak it back into shape.
dracken1
« Reply #304 on: February 28, 2008, 01:07:11 AM »
take it easy. as you can tell by the weight of them they are made from brass then chromed. if the lever is the same material it's like cast ali... it will easily bend once. but twice is another thing
« Reply #305 on: February 28, 2008, 07:50:11 AM »
Had a look at the petrol tap this morning and it looks like it should have a curve in it. There are little notches that it sits in on each of the 3 settings and the curve is just on the edge. Manky is going to look at his one. The tap is stiff in the movement but if it bent through that then it would be bent sideways but it's bent down. That's the only time it's been out the box so I'm sure it's ment to be like it.
« Reply #306 on: February 28, 2008, 07:55:21 AM »
No it's not, it's meant to be straight I may have a spare in my scrap brass box, will have a look for you
« Last Edit: February 28, 2008, 09:05:47 AM by TwistedPatience » Logged
« Reply #307 on: February 28, 2008, 07:56:32 AM »
Oh  Sad
dracken1
« Reply #308 on: February 28, 2008, 11:45:41 AM »
as twisted has stated it should be straight.
i have 4 brand new ones here.
if it breaks send it back and i'll get another off to you.
it would bend if it was dropped
and yes a are a little stiff but do wear in.
but any doubts and i will replace it  "foc" Wink
« Reply #309 on: February 28, 2008, 11:52:34 AM »
cant argue with that Smiley
dracken1
« Reply #310 on: February 28, 2008, 01:40:45 PM »
AHH IT'S NOT QUITE AS EASY AS IT SOUNDS.
it left here well packed and straight.
so to get a replacement, one of them will have to publically proclaim to be ham fisted and have 10 thumbs Grin Grin Grin
« Reply #311 on: February 28, 2008, 02:43:54 PM »
pmsl
« Reply #312 on: February 28, 2008, 09:08:43 PM »
Don't worry about it, it feels strong and I'm fine with it as it is and it still works as it should.  Grin
« Reply #313 on: February 28, 2008, 09:10:12 PM »
oooh no ones owning up then Smiley
« Reply #314 on: February 28, 2008, 09:13:42 PM »
I can't own up to something that I have no clue about how it happened. Just one of them things.
