March 05, 2026, 01:02:08 PM *
Poll
Question: SUGGEST A COLOUR FOR MY TRIKE
ARMY GREEN - 18 (58.1%)
BLACK - 13 (41.9%)
Total Voters: 28
Pages: 1 2 [3] 4 5 ... 8
Author Topic: Willy's Skorpion Trike Re-build (Restoration ) Poject  (Read 56266 times)
willy
« Reply #30 on: May 31, 2007, 05:37:43 AM »
Manky Monkey.....I have done a write on my project part 1 where do i send it to so you can post it on the motors page......Cheers......Willy
« Reply #31 on: May 31, 2007, 08:32:32 AM »
Hiya,
check the Contacts page of the main site. You'll find Yoda's & my email addresses. Either one will do -& thanks Willy. Grin
willy
« Reply #32 on: May 31, 2007, 04:11:56 PM »
manky...i have sent it to you via e.mail...cheers.....willy
« Reply #33 on: May 31, 2007, 08:54:02 PM »
Received your email Willy, but the piccies are too small. Could you email me larger versions please.
willy
« Reply #34 on: May 31, 2007, 10:23:52 PM »
some of them are only small but i have sent you another e.mail....cheers.....willy
willy
« Reply #35 on: August 28, 2007, 04:08:36 AM »
Got a new clutch cylinder to from ''jorily'' as the other one is knackered. So fitted that today now i'm back in action,i found out today that the brake cylinder on my Skonda is actually a clutch cylinder.So that answers the question in another post i made ''can i use'' so i will order another clutch cylinder to use as the brake cylinder......Willy
UPDATE ON THE SKONDA....Right here we go at last ... I have stripped her down even further i was thinking that if i change the rake and put some longer forks on (if possible)..1, it will look better i think and..2, hopefully it will make the front a bit heavier helping to keep the front end on the ground .I have now stripped the front end of ready to alter the rake when i can get someone to cut it and weld it for me as i don't weld.Not sure what front end to use it needs to be from a Honda of some sort so that i can keep the name i've chosen for it (THE SKONDA).I will post some pictures later hopefully...cheers.....Willy
http://img528.imageshack.us/img528/6941/97532922jf2.jpg
http://img45.imageshack.us/img45/6497/i218693664747337md5.jpg
« Last Edit: September 12, 2007, 09:36:21 PM by willy » Logged
« Reply #36 on: August 28, 2007, 06:22:47 AM »
Hi Willy. Go for the beefiest teles you can find to take the weight of half a Skoda hanging on them, or try leading link forks. I'll be interested to see the results.
willy
« Reply #37 on: August 29, 2007, 02:33:23 AM »
manky ... and i will interested to see the result...lol.......willy
willy
« Reply #38 on: September 12, 2007, 09:43:21 PM »
Well i done i bit more to her today,i painted the frame and seating area with Black agricultural paint similar to hammerite smooth...looks like new now...lol
http://img502.imageshack.us/img502/712/imag0164gj8.jpg
willy
« Reply #39 on: September 14, 2007, 12:12:28 AM »
found a 1951 gerry can to use as a mock petrol tank,will need to move hand brake and gear stick to mount it though,mock up pics to follow,also put forks back on...got the olive drab paint today ( army green )....willy
Nomad
« Reply #40 on: September 14, 2007, 12:23:52 PM »
Hey willy, if the black was similar to "smoothrite" it will be an enamel and you may get a reaction if you overpaint with cellulose or 2 pak. If you are can I suggest a test are first.
Best of luck.
If all around you are losing their heads, land your helicopter somewhere else.
willy
« Reply #41 on: September 14, 2007, 12:25:53 PM »
nomad..i aint going to paint over it...cheers.....willy
willy
« Reply #42 on: September 14, 2007, 03:24:08 PM »
found a 1951 gerry can to use as a mock petrol tank,will need to move hand brake and gear stick to mount it though,mock up pics to follow,also put forks back on...its getting there
willy
« Reply #43 on: September 14, 2007, 03:25:00 PM »
Here are those pics....
http://img214.imageshack.us/img214/6471/imag0180jf8.jpg
http://img214.imageshack.us/img214/7231/imag0174mw7.jpg
http://img210.imageshack.us/img210/6681/imag0188ay6.jpg
http://img260.imageshack.us/img260/2326/imag0187ul3.jpg
« Reply #44 on: September 14, 2007, 05:40:29 PM »
There was a bike at our local bike meet with a similar tank a couple of months ago. Certainly got plenty of attention.  Smiley
