March 28, 2024, 01:07:31 PM *
Pages: 1 ... 747 748 [749] 750 751 ... 791
Author Topic: Manky's Pop.  (Read 1537212 times)
« Reply #11220 on: December 01, 2019, 11:38:10 AM »
« Reply #11221 on: December 01, 2019, 11:38:54 AM »
« Reply #11222 on: December 01, 2019, 11:39:19 AM »
« Reply #11223 on: December 01, 2019, 04:31:18 PM »
Finally got some black on it.
Just a first coat -there's at least one run & one spot of bubbly reaction -but it's progress.
No idea how I'm going to do this cos I need to fully paint the removable diff casting & bolt it back down, then add a smear of Araldite around the joint to seal it, before final paint on the rest. I'm sure something will end up scratched up.
I vaguely remember the diff weeping oil & a previous owner had sealed it with chemical metal, but presumably while the axle was still in the original Sherpa van. Looks like the bodge was done on top of oily metal so hadn't fully adhered & oil was weeping out underneath the sealant.
It's a bodge to Araldite it, but I'm not disturbing the diff to replace the gasket.
Then once it's fully painted I need to re-fit the hubs, driceshafts & brakes, then somehow get it under the Pop without destroying the paint.
« Reply #11224 on: December 01, 2019, 04:31:42 PM »
« Reply #11225 on: December 01, 2019, 04:32:23 PM »
« Reply #11226 on: December 01, 2019, 04:32:47 PM »
« Reply #11227 on: December 01, 2019, 05:48:50 PM »
Who's pop van is that?  I'm sure you must have a mate to help you with the axle?  Bolt it in first and then fit everything else after
« Reply #11228 on: December 01, 2019, 06:41:16 PM »
Nobody nearby to help.
I'm working in a small lock-up & don't have the room to fit both driveshafts with the axle in place. The brake back plates have to go on first, before the floating hubs & driveshafts, so it all has to be done off the car.
« Reply #11229 on: December 02, 2019, 10:37:40 PM »
The Pop belongs to a guy on a Facebook Pop owners' page.
tom_prs
« Reply #11230 on: December 03, 2019, 08:26:43 AM »
I'd be happy to help lift it in with you Andy, just give me a message when it's ready  Grin
« Reply #11231 on: December 03, 2019, 09:05:01 AM »
Me too mate, just say the word.
Me and Tom can do the heavy stuff and you can direct
« Reply #11232 on: December 03, 2019, 05:21:39 PM »
Ha ha Smiley
Thanks, I might take you up on that chaps!
-don't worry though, it'll be a while yet.
The Pop's sat quite close to one wall of the garage, so I need to get at least one hub/drive shaft assembly re-fitted once I've painted the axle.
« Reply #11233 on: December 04, 2019, 08:17:08 PM »
I think you'd make a lot more progress if you had a garage like that!!
Baychimp
« Reply #11234 on: December 04, 2019, 11:39:33 PM »
I keep telling you! You only have to text,I still have the same phone number. I haven't been around for a while because my sister was over from Australia and have been spending a lot of time with them. Gone back now.
