April 20, 2024, 09:33:45 AM *
Pages: 1 ... 744 745 [746] 747 748 ... 791
Author Topic: Manky's Pop.  (Read 1545174 times)
« Reply #11175 on: October 30, 2019, 07:09:48 AM »
Sounds like your repeating your mistake from earlier Andy 😨? Working in that damp garage with spray paint just isn't going to work..maybe make some type of wooden spray booth around the axle and keep that area warm for a few hours?
« Reply #11176 on: October 30, 2019, 09:25:55 AM »
I've got a pair of small camping heaters stood underneath it while I'm working on it.
« Reply #11177 on: October 30, 2019, 06:43:16 PM »
You need to have heat on it before/during/after working on it mate 👍😁
« Reply #11178 on: October 30, 2019, 09:32:22 PM »
I know -learnt that from working on the chassis. Maybe I should ship it out to you in the sunshine to paint for me?! Smiley
« Reply #11179 on: October 31, 2019, 08:00:43 AM »
Can you imagine the cost 😨
« Reply #11180 on: October 31, 2019, 11:08:54 AM »
« Reply #11181 on: October 31, 2019, 06:33:16 PM »
I can send you some Spanish paint..it's warmer 🤣😎
« Reply #11182 on: October 31, 2019, 10:34:25 PM »
Presumably gas ones?   You do know that one of the products of combustion is water?
« Reply #11183 on: October 31, 2019, 10:36:41 PM »
Butane. I have a couple of moisture traps in the garage -those plastic boxes full of granules that collect condensation. They usually need replacing about once a month.
« Reply #11184 on: November 05, 2019, 06:48:52 PM »
Stoopid axle.
Stopped at my garage after work this afternoon, put the heaters on for an hour or so & squirted some more primer on the diff casing. Then I had to sit for another hour waiting for the paint to go off so I could switch the heaters off & come home. Looks a lot better in photos than it actually is, but not too bad. Still got the bracketry around the ends to sand.
Don't know how I'm going to paint the top coats. A previous owner had chemical mettall'd around the base of the diff housing, but the oil has got under it & lifted it -I have a vague recollection of it leaking last time it was on the road. There's no way I'm taking the housing off & disturbing the gears to replace the gasket, so I'll end up using a smear of Araldite around it I think, (hopefully I can make a better job of it with the axle out of the car). That means I need to fully paint the diff & bolt it down tight first, then Araldite it, then paint the tubes without damaging the diff paint -on an axle that weighs a bloomin' ton & is a nightmare to move about.
Once it's done & back in the car I'll be able to roll it out of the garage & turn it around. Lots of jobs, like brake lines, fuel lines etc can be done then, as well as trial fitting the tatty old doors before cleaning them up & painting them.
So-o-o much to do.
« Reply #11185 on: November 05, 2019, 06:52:55 PM »
2 little butane camping heaters to warm the garage. Fortunately I've insulated the roof, so once it's warmed up, it's quite cosy in there.
I swore I wasn't going to spend another Winter in the garage, but looks like I'll be here till the Spring.
I've already booked the accomodation for the Dutch hotrod show in April, but have no idea if I'll be ready in time or if I'll be able to get the time off work.
« Reply #11186 on: November 06, 2019, 08:14:07 PM »
Some gloss black on the axle this evening.
I'm only concerned with the diff housing at the moment & still have filler to sand around the bracketry on the tubes. Doesn't look too bad at the moment, but I'm sure it'll look horrendous in daylight. At least it's progress. Smiley
Yes, it's stupidly obsessive, but I'm going to run the pick-up bed without the floor, (I'm never going to carry anything in it anyway), so the chassis & axle will be on show.
« Reply #11187 on: November 06, 2019, 08:44:45 PM »
Just checked it again before leaving the garage. Loads of reaction/wrinkling.
*sigh*
Rub it down. Do it again.
« Reply #11188 on: November 07, 2019, 07:03:32 AM »
By the time you have driven it to Holland it's going to be covered in road Rash anyway?  Why not just take it to a decent spray shop and pay them?
« Reply #11189 on: November 07, 2019, 05:05:26 PM »
Biggest problem with that is the logistics of getting it there _& back again without damaging the paint. It's ridiculously heavy, won't fit in my car & also still needs filling & sanding around the various brackets, (there's some big heavy dust welding that I want to smooth out).
It costs me nothing but my sanity to spend a few afternoons filling & sanding, although I'm lacking motivation so it's dragged out over several weeks so far. A paintshop would charge me a fortune for the same work. I'd also need to rent a van to take it anywhere & again to bring it back & you can guarantee it'd get damaged in transit.
My brother paints & Clive has also suggested someone, but most work in 2 pack & won't spray it over aerosol primer.
I'd like to do it myself, just for my own pride, but it's a horrible job & I'm really not enjoying it. Not really enjoying the build as a whole, but want to finish the damn thing & drive it again, so need to stop whinging & get on with it Smiley
