April 26, 2024, 02:52:51 AM *
Pages: 1 ... 710 711 [712] 713 714 ... 791
Author Topic: Manky's Pop.  (Read 1547891 times)
« Reply #10665 on: August 14, 2018, 09:17:20 PM »
And the back bit's welded to the chassis, so would stay behind when/if the body comes off.
There's a storage box that bolts to the cab back & sits on top of the tunnel, so it'd be good to get it upholstered now, before the box goes in.
« Last Edit: August 14, 2018, 09:28:22 PM by Manky Monkey » Logged
« Reply #10666 on: August 14, 2018, 09:25:40 PM »
I was going to drive the finished truck to an upholsterer for these to be done. I did think about temporarily spraying the Dynamat with textured black stonechip type paint, (the Halfords pick-up bed liner spray I've used around the switch panel), but I expect the upholsterer would refuse to try & glue vinyl to that. It'd also scuff off pretty quickly in the footwells either side of the front of the tunnel.
So I've bought some vinyl from eBay & will have a go at making paper templates, cutting it & gluing it myself. What could possibly go wrong?!
20 quid's worth of vinyl arrived today. The grain's a bit heavier than the rest in the cab, but I can live with that. It's about 1/2 a mill' thick.
Any recommendations for glue?
Sid_Vicious
« Reply #10667 on: August 14, 2018, 09:48:16 PM »
You can use sprayglue or contactglue, same stuff only different methods on how to apply it on. Apply it on both sides and let it dry for a moment before sticking it together. Another tip is to have a heatgun to soften the fabric a bit so it is easier to stretch over the tunnel. That's what I used to do when I worked with upholstery in boats.
Baychimp
« Reply #10668 on: August 14, 2018, 09:56:09 PM »
Evo stick will do it. We used to put vinyl roofs on cars with it.
« Reply #10669 on: August 14, 2018, 10:25:54 PM »
Where can I buy contact glue?
Sid_Vicious
« Reply #10670 on: August 14, 2018, 11:31:32 PM »
Diy shops, Hardware stores, Maybe Halfrauds, or ask a shoemaker where to buy it they use it all the time. Or try Evilbay.
« Last Edit: August 14, 2018, 11:34:15 PM by Sid_Vicious » Logged
« Reply #10671 on: August 15, 2018, 12:47:10 PM »
ME! We've got it here for the lining carpet
in spray form or tins to paint on
« Reply #10672 on: August 15, 2018, 01:16:22 PM »
Aha Smiley
I've messaged you Archie.
phunkie hiboy
« Reply #10673 on: August 15, 2018, 10:01:49 PM »
Archie, is the paint on stuff, the high temperature type? 'cos if it is, it would save me driving all the way down to Boyrivens when I need it.
« Reply #10674 on: August 16, 2018, 11:27:52 AM »
Just checking the the tin in front of me - lists as High temperature contact adhesive HTA1000
It’s made by wayside adhesives and has UN1133 on it under the danger heading - it does have Toluene in it which I know is a bit nasty.
« Reply #10675 on: August 16, 2018, 01:04:21 PM »
a good adhesive if it contains toluene, used it in marine industry for years.
just make sure you use it outside andy due to very high fumes.
« Reply #10676 on: August 16, 2018, 04:05:57 PM »
Toluene...............
Used to used in cans of octane-booster that could be bought in High Street motor accessory shops many moons ago, and was part of the exotic fuels used in some pre war race cars.
Not clever stuff for hooman beens re fumes as Poprodder says, may also be absorbed through the skins, so suitable gloves are recommended.  Wink
https://fscimage.fishersci.com/msds/23590.htm
« Reply #10677 on: August 16, 2018, 05:30:50 PM »
toluene is/was used in explosives.
« Reply #10678 on: August 16, 2018, 08:48:02 PM »
Tri Nitro Toluene - TNT!
« Reply #10679 on: August 16, 2018, 09:36:04 PM »
