April 25, 2024, 07:28:12 PM *
Pages: 1 ... 677 678 [679] 680 681 ... 791
Author Topic: Manky's Pop.  (Read 1547734 times)
« Reply #10170 on: February 05, 2018, 11:03:00 PM »
They're going for a streamlined Bonneville salt racer look. The front axle's been pulled forward, like mine, but he's also raked the rear of the roof forward, then taken a wedge out of the bootlid surround so it follows the new angle of the rear window. Lots of work but it gives it a unique, sportier stance.
« Last Edit: February 14, 2018, 12:03:34 PM by Manky Monkey » Logged
« Reply #10171 on: February 13, 2018, 08:07:11 PM »
Arrived home from the garage looking jaundiced this evening -I've been spraying thick yellow filler/primer inside the cab -like spray-on custard, but not as tasty when you end up ingesting most of it. Actually, I hate custard, so it tasted better.
« Reply #10172 on: February 13, 2018, 08:13:03 PM »
The flash makes it look brighter than it is.
I'll flat it back, then go over it in normal grey primer, flat that back & try a few coats of green.
I've decided to go for gloss now, rather than the satin green I put on before. The body's still wobbly in places, which will show more in gloss, but at least it's smoothly wobbly. I like to think it's organically curvy -like me Smiley I can live with the wobbles.
So I'll use what's left of the satin paint to build up a bit of depth before finishing with the gloss.
Baychimp
« Reply #10173 on: February 13, 2018, 10:35:08 PM »
So is that all the filling and rubbing down done Andy.
« Reply #10174 on: February 14, 2018, 09:39:39 AM »
Filling done. Rubbing down the primer now. It's a long way from perfect, but I'll get it as presentable as I can in a lock-up garage in the middle of February Smiley
« Reply #10175 on: February 14, 2018, 10:13:05 AM »
.but I'll get it as presentable as I can in a lock-up garage in the middle of February.
sounds about right. That could be one of those arty film noir things Andy. Lock up garage in February  Cheesy
« Reply #10176 on: February 14, 2018, 10:30:01 AM »
Film Yellow at the moment.
« Reply #10177 on: February 14, 2018, 11:29:47 AM »
I tried. but the yellow filter is a bit naff
« Reply #10178 on: February 14, 2018, 11:37:57 AM »
Smiley Sepia!
I did seriously think of gloss battleship grey at one point.
« Reply #10179 on: February 14, 2018, 05:12:21 PM »
Deja vu seems to come to mind ? Grin
« Reply #10180 on: February 14, 2018, 10:58:44 PM »
Again! Smiley
« Reply #10181 on: February 14, 2018, 11:40:43 PM »
More like Ground Hog day.........revisited Cheesy
« Reply #10182 on: February 15, 2018, 11:18:38 AM »
I don't know how I'd carry on with this without the sympathy & support of you lot Smiley
« Reply #10183 on: February 15, 2018, 12:38:00 PM »
Grey primering. Ran out of paint halfway through -yeah, I know -forward planning Smiley Warming the garage as much as I can with a small butane heater. I know butane can produce moisture in the air, but no obvious problems so far.
Already spotted one run on the A pillar -don't touch it, no matter how tempting it is! & a nick in the filler that needs re-doing. It always looks good when it's first done, but I know from bitter experience that it'll sink after a couple of days & all the sanding marks will show & it'll look horrible Sad
Several heavy coats, then leave it for a day before flatting it back with 1200 grit, (the Emery paper I buy from ScrewFix goes from 600 straight to 1200. Could do with an 800 grade really).
Off to Halfords for more paint.
« Reply #10184 on: February 15, 2018, 12:39:47 PM »
