April 25, 2024, 04:37:08 PM *
Pages: 1 ... 664 665 [666] 667 668 ... 791
Author Topic: Manky's Pop.  (Read 1547666 times)
« Reply #9975 on: October 31, 2017, 09:31:07 AM »
I use it cos it's just a good, cheap industrial finish. Fine for most of my stuff. Never had it chip off -it usually scuffs because it's not brittle like paint.
Everybody's got their favourite & I guess you stick to what you like. Smiley
« Reply #9976 on: October 31, 2017, 11:55:51 AM »
Is this an omen. The Pop has reached that number. χξϛ
or perhaps it did 50 pages ago.
« Reply #9977 on: October 31, 2017, 02:01:41 PM »
Ooooh, creepy!  Shocked
« Reply #9978 on: October 31, 2017, 05:49:04 PM »
So fed up with this.
Seem to be doing & re-doing the same stuff over & over again. It is progressing, but so slowly.
Yellow filler primer squirted over the panels I sanded down last week. I had to rub them down & re-fill them after I cleaned up the bulkhead & sanded some welds with the angle grinder, which bubbled the original skim of filler. Another week & I should be back where I started.
« Reply #9979 on: October 31, 2017, 05:49:36 PM »
Maybe I should just spray it all in yellow primer & leave it at that -the Banana-Mobile.
« Reply #9980 on: October 31, 2017, 05:52:51 PM »
Drilled the bulkhead, painted around the edges of the holes & fitted the remote bleed nipples for the servo.
« Reply #9981 on: November 01, 2017, 06:48:41 PM »
Been waiting 2 weeks for Doug the engineer to machine 2 mild steel slugs for me, that'll be welded into the frame loop under the dash, to make it removable.
I contacted him yesterday & he admitted he'd lost my diagram. So I had to re-measure & re-draw it this afternoon & drop it down to his workshop.
This is his big block Ford powered Zephyr daily driver. He was working on it when I first started taking work to him about 25 years ago. It finally hit the road 6 months ago.
« Reply #9982 on: November 06, 2017, 05:43:40 PM »
Still waiting for the machinist & 2 different welders to do their thing.
Sat in the garage, rubbing down filler in the Pop cab, the thermometer says it's minus 3 -& I've just heard an ice cream van go past! He's 'avin' a larf in't he?!
« Reply #9983 on: November 06, 2017, 05:53:12 PM »
never to cold for a 99
« Reply #9984 on: November 06, 2017, 07:04:16 PM »
 Tongue
« Reply #9985 on: November 06, 2017, 07:23:24 PM »
https://i.pinimg.com/originals/8c/2b/1f/8c2b1f63022cfe1d573df2df92b06778.jpg
Manky's Pop.
« Reply #9986 on: November 06, 2017, 07:38:57 PM »
« Reply #9987 on: November 10, 2017, 08:34:40 PM »
Dark evenings working by the light of an LED lamp. It's re-chargable but only lasts for about an hour & a half.
Light goes out -I go home.
Loads to do but not getting much achieved at the moment.
« Reply #9988 on: November 11, 2017, 06:41:05 PM »
Hi,,Andy as regards LED work lights I use some I bought of eBay and the 10watt  one is bright enough and lasts for a good  four hours
EBay item number  322721484119
« Reply #9989 on: November 11, 2017, 07:06:04 PM »
Same type I've got Mike. I've had them a couple of years & I think they're gradually lasting less & less time on each charge.
