April 27, 2024, 02:37:23 PM *
Pages: 1 ... 650 651 [652] 653 654 ... 791
Author Topic: Manky's Pop.  (Read 1550020 times)
« Reply #9765 on: August 27, 2017, 10:49:10 PM »
 Cheesy I can add a half-round sleeve down the back face of it, which will help.
Stix
« Reply #9766 on: August 27, 2017, 11:02:40 PM »
 Grin Grin. Anything that will stop you having to stop and pick em up on a dark night. Kiss
« Reply #9767 on: August 27, 2017, 11:24:50 PM »
 Cheesy
« Reply #9768 on: August 28, 2017, 10:16:04 AM »
Yes Dave -the rods are the limiting factor at the moment. Obviously they'd be internally sleeved & fully welded.
If you've enough thread at the thin end heat and bend 'em?
« Reply #9769 on: August 28, 2017, 04:05:14 PM »
Problem not exactly solved, but it's no longer an issue.
Can't alter the rods cos they'll end up directly under the shock absorbers & would foul on full suspension travel. Didn't realise cos I've taken the shock off to paint the chassis & only saw it when I looked at the other side.
I'd still like to add a leaf or two into the front spring to stiffen it up a bit, but will have to live with the limited steering lock for now. Moving the headlight has given some much needed clearance though.
« Reply #9770 on: August 28, 2017, 04:34:44 PM »
I'm sure you can stiffen up the shocks or replace with another type ?
« Reply #9771 on: August 28, 2017, 09:02:24 PM »
I wondered about that as an easy option. They're the rear dampers from a Morris Minor saloon. No idea how you'd even start looking for stiffer ones with the same mounting hole measurement.
Stix
« Reply #9772 on: August 28, 2017, 09:23:51 PM »
Can't you put-thicker oil in them???
« Reply #9773 on: August 28, 2017, 10:35:43 PM »
Can't remember what's in there, but got a feeling it's probably standard engine oil. I think the front suspension will be something I'll just have to experiment with once it's back on the road -I've almost forgotten what it's like to drive now Sad
Stix
« Reply #9774 on: August 28, 2017, 11:05:49 PM »
If it's multi gradeie20/50 15/40. It will act like the thinnest number when cold, maybe try straight 30 or 40 as that will stay constant from cold to hot .
Stix
« Reply #9775 on: August 28, 2017, 11:19:30 PM »
Well you could try some silkolene fork oil - it comes in different grades, and those moggy shocks weren't much good even back in the day.
On the fouling issue, just raise them up and extend the links?
« Reply #9776 on: August 29, 2017, 06:18:33 AM »
Well some fork oil will definitely stiffen up them for sure. Smiley are your lever shocks mounted to your steering cross arm ?  And in replacing them I was thinking maybe some small diameter coilovers from a motorbike ?
lunatic
« Reply #9777 on: August 29, 2017, 09:56:23 AM »
They've got heavy duty Harley fork oil in them already.
toad
« Reply #9778 on: August 29, 2017, 07:26:30 PM »
Straight 40 is what should be in them. Wink
« Reply #9779 on: August 29, 2017, 09:26:15 PM »
Hello chaps Smiley Glad someone's got a better memory than me. The drop arms mount to the inside face of the radius rods. It all works fine, but is just a bit soft & I was hoping stiffening it might effectively limit it's travel.
