« Reply #6585 on: July 28, 2013, 06:43:35 PM » |
« Reply #6586 on: July 28, 2013, 06:45:50 PM » |
Loony tries it for size. The big question now is- in the straight ahead position, should the spokes be + shaped or X shaped?
« Reply #6587 on: July 28, 2013, 07:10:47 PM » |
X
« Reply #6588 on: July 28, 2013, 07:14:01 PM » |
Yeah, that seems logical if you're holding the wheel at the 3.0.clock & 9.0.clock positions Clive -but I've got a feeling old 4 spoked cars like Model Ts for instance, had them in the + position. Not that it really matters -there's about 2 inches of freeplay in the steering box, (normal I was told, even by the SVA examiner), so I can turn it almost 90 degrees without the wheels actually changing direction at all.
« Last Edit: July 28, 2013, 07:23:20 PM by Manky Monkey »
« Reply #6589 on: July 28, 2013, 07:17:58 PM » |
+ Now I just need to find someone to machine me a new mounting boss, hopefully incorporating the Monkeyhead centre cap from the Moggy wheel -yes, I'm looking at you Mr Newbie!  I shall pretend that I didn't just read that!
Baychimp
« Reply #6590 on: July 28, 2013, 07:20:52 PM » |
Its no good pretending Dave. We know you have,"BUSTED".
« Reply #6591 on: July 28, 2013, 07:25:37 PM » |
Sorry Dave. I was going to PM you about it before posting here! Fancy a little paying commission? The new wheel's got a 5 or 6 splined centre boss, while the Moggy steering column has a single Woodroffe keyway I think.
« Reply #6592 on: July 28, 2013, 07:38:26 PM » |
Lovely wheel  Question is more where do you hold the wheel as to which looks better , when cruising it should be comfortable.
« Reply #6593 on: July 28, 2013, 07:45:48 PM » |
For some reason I was expecting you to tell me off for buying it Uncle Kev! The current Morris Minor wheel has 2 horizontal spokes, so I usually drive with my right hand on the wheel & my thumb hooked over the spoke, (on normal roads it's light enough to steer with just one finger & thumb). So I guess the + position would work best. Need to smooth the back of the spokes though cos they're a bit raw edged at the moment.
« Reply #6594 on: July 28, 2013, 08:12:43 PM » |
FORDSON STANDARD N, STEERING WHEEL..
« Reply #6595 on: July 28, 2013, 08:25:58 PM » |
Well spotted Mike. You are indeed correct.
« Reply #6596 on: July 28, 2013, 08:28:18 PM » |
skipped a steering box/coloum last week. well i actually ,skipped, half a tractor
Baychimp
« Reply #6597 on: July 28, 2013, 08:41:43 PM » |
Andy, any pictures of Netley marsh.
« Reply #6598 on: July 28, 2013, 08:52:08 PM » |
Bugger! Yup, posting them as we speak Bob.
« Reply #6599 on: July 28, 2013, 10:00:46 PM » |
Money could have gone towards a performance cam or rings , or bearings or...  We'll have to fit you with reins, like Anton, to keep a tight hold to keep you away from the 'bling'.
