April 25, 2024, 06:10:43 AM *
Pages: 1 ... 742 743 [744] 745 746 ... 791
Author Topic: Manky's Pop.  (Read 1547477 times)
« Reply #11145 on: September 11, 2019, 09:25:57 PM »
« Reply #11146 on: September 13, 2019, 06:54:00 AM »
Probably a lot easier to make from new, using marine fittings. Look at rigging screws etc. from a company such as-   https://www.gsproducts.co.uk/
« Reply #11147 on: September 13, 2019, 01:55:12 PM »
if you've got a length i can check cables here if any are similar
are you running a centre cable to 2 or just 2 full length ones?
« Reply #11148 on: September 13, 2019, 03:03:57 PM »
Thanks Dave.
I've got a brand new Sherpa cable, (it's a Sherpa axle). Single cable running between the 2 drums, pulled by a pulley on the handbrake lever. This is just a means of adjusting it.
« Reply #11149 on: September 13, 2019, 08:20:09 PM »
Nuthin' much to report. The evenings are already starting to draw in & by 8.0.clock I was painting rust killer on the ends of the axle by the light of my Led worklamp. At least it's still warm enough to work in a T shirt.
« Last Edit: September 15, 2019, 07:43:28 PM by Manky Monkey » Logged
« Reply #11150 on: September 15, 2019, 07:43:07 PM »
Next section of vinyl cut & glued, (the recess around the steering column mount). I need something to fill a few gaps between the joints. Some sort of matt black mastic or thick polish maybe, to hide the seams.
Any suggestions?
« Reply #11151 on: September 15, 2019, 07:51:09 PM »
Wasted an hour or two this morning trying to sand down several layers of paint & rust on the back axle, before giving up & attacking it with an old screwdriver. Looks like a previous owner has used some sort of chemical metal around the diff housing seal. I have a vague memory of it leaking last time it was on the road -it looks like the oil has got under the sealant & lifted it. I know it's a bodge, but there's no way I'm going to remove the diff casing & disturb the gears to replace the gasket, so I'll clean it back to bare metal & apply something else -good old fashioned Araldite?
« Reply #11152 on: September 15, 2019, 08:15:58 PM »
Matt black silicone mastic should be OK for your trim gaps.
Old fashioned Araldite, preferably not the fast setting, should be fine, if you can remove all traces of oil first.
« Reply #11153 on: September 15, 2019, 09:57:56 PM »
Thanks Dave.
« Reply #11154 on: September 16, 2019, 09:30:54 PM »
Another section of vinyl cut & glued. I had to buy a copy of The Guardian just to get big enough sheets of newspaper to make the patterns! I'm waiting 24 hours between pieces before trimming them to size, even though the impact glue seems to set almost straight away.
Did a bit more rust removal on the rear axle outside the garage, until rain stopped play for the evening.
« Reply #11155 on: September 22, 2019, 05:33:16 PM »
I've been to the "Popstalgia" show in Leicestershire this morning. 47 Pops in a field -but not mine Sad
Every year I say it'll be there next time.
Next year it'll be there. Honest.
« Reply #11156 on: September 24, 2019, 08:54:35 PM »
As usual, not much to report, but I'm messing with various bits of vinyl trim inside the cab, while also rubbing down the rear axle.
Quickly blown over with some Halfords spray-on custard high build primer, (horrible stuff, but the only primer I had to hand at the time). It looks alright in the photo, but is actually covered in runs & wrinkles & has reacted with old paint underneath in several places, but at least shows me what still needs sanding or filling. I really should've done this several weeks ago, before the cold, wet weather arrived. Rain stopped play this evening.
I've had a back ache for about a week now & suddenly realised today it's the result of lugging this thing about -yes, I am that stupid. It weighs a ton. Be careful out there people.
« Reply #11157 on: September 24, 2019, 10:26:31 PM »
Well Winter doesn't officially start till 22nd of December so you may get some hot days yet 🤣🙊🙉🙈
« Reply #11158 on: September 25, 2019, 03:12:16 PM »
You could probably pick up some kind of heavy duty trolley to move that about fairly cheaply on Ebay or similar.  Don't want to riisk having to have time off with your back!
« Reply #11159 on: September 25, 2019, 05:20:30 PM »
I'm working at the Post Office this week with a girl who's 30 years younger than me. I keep lecturing her about using the trollies Royal Mail provide, rather than carrying 2 bags of Mail on her shoulder. She doesn't listen
-I hate using the trolley. It slows me down.
Not as much as a knackered back will in a few years time.
-then I go home & lift that axle about.
