April 27, 2024, 05:13:49 AM *
Pages: 1 ... 735 736 [737] 738 739 ... 791
Author Topic: Manky's Pop.  (Read 1549686 times)
« Reply #11040 on: June 12, 2019, 04:15:47 PM »
Yes but if you're underneath that means you're worrying about bits that no-one but you will see!
« Reply #11041 on: June 16, 2019, 05:34:17 PM »
« Reply #11042 on: June 16, 2019, 06:15:15 PM »
Great sticker!  Grin
« Reply #11043 on: June 16, 2019, 06:37:38 PM »
Indeed..I want one
« Reply #11044 on: June 29, 2019, 09:57:39 PM »
Looks exactly the same Yeah, but now it's utterly lacquered.
« Reply #11045 on: June 29, 2019, 09:58:32 PM »
Lots of runs to sand out, but hopefully that'll be it then.
« Reply #11046 on: June 29, 2019, 10:30:56 PM »
I got back from my holiday yesterday to find it's 90 degrees here.
Now I'm suffering from jet lag, heat exhaustion & paint fumes -not a good combination!
« Reply #11047 on: June 30, 2019, 07:16:48 AM »
Andy, your back and in 3 posts your moaning about something 🤣 I thought the idea was to chill out on holiday?
« Reply #11048 on: June 30, 2019, 09:01:21 PM »
Ha ha, sorry. I really didn't want to come back.
Checked on the chassis today. Not looking too bad, but a few runs to rub out. The aerosols kept dribbling drops of paint as I was spraying. Haven't had that before -maybe to do with the heat? I spent ages shaking them. So I've got some blobs to sand out too. I've got 2 cans left & really want to make sure the underside's all covered cos there's nooks & crannies I can hardly reach, so will clean it up then blow another coat over the underside.
Then I've got to paint the axle! Smiley
skippy
« Reply #11049 on: July 02, 2019, 05:24:19 AM »
looking good but you need to put it back together and enjoy , get one of these slide on's and getting traveling . Life's short enough  Wink
« Reply #11050 on: July 02, 2019, 08:47:10 AM »
Saw a couple of those in the States last week.
skippy
« Reply #11051 on: July 02, 2019, 08:30:22 PM »
They are here to , a lot of them are for hire [Ute + slide on] for tourists .
https://www.google.com/search?q=slide+on+campers+for+hire&rlz=1C1CHZL_enAU830AU830&source=lnms&tbm=isch&sa=X&ved=0ahUKEwii56bOiZfjAhUJ-hQKHaJqBi8Q_AUIESgC&biw=1280&bih=609
Dave
« Reply #11052 on: July 07, 2019, 09:37:19 PM »
After the tragic death of Simon Nefarious Pollock this week -a good friend & superb painter who was supposed to signwrite the doors of my Anglia pick-up last year, but it wasn't ready -I've decided I really need to crack on with this rebuild & get back out & enjoy it -before my time's up too.
So this weekend I've finally finished faffing about with the chassis paint. It's taken s-o-o long to sort out. I'm working in a rented lock-up garage with no power supply & limited heat, (small butane powered camping heaters), so had to give up trying to paint over the Winter & have only recently re-discovered my building mojo.
I've repaired a couple of patches in the green cab paint, including the flat panel below the swage line on the back, which need lacquering to blend in with the rest of the cab. Then I'll mask the chassis up & spray some textured black stonechip paint around the inside bottom edges of the cab & under the sills.
I hung the rear shocks on this evening, just to see how they look against the shiny chassis.
Next big job is to spray the rear axle to match & refit it so I can roll the thing outside.
« Reply #11053 on: July 07, 2019, 09:37:53 PM »
« Reply #11054 on: July 07, 2019, 09:39:01 PM »
