April 26, 2024, 07:04:20 AM *
Pages: 1 ... 728 729 [730] 731 732 ... 791
Author Topic: Manky's Pop.  (Read 1547980 times)
« Reply #10935 on: January 21, 2019, 11:07:29 PM »
« Reply #10936 on: January 21, 2019, 11:09:17 PM »
« Reply #10937 on: January 21, 2019, 11:11:40 PM »
« Reply #10938 on: January 21, 2019, 11:13:08 PM »
« Reply #10939 on: January 21, 2019, 11:14:50 PM »
« Reply #10940 on: January 22, 2019, 06:42:07 AM »
 You have doors ! Well almost.
« Reply #10941 on: January 22, 2019, 09:26:59 AM »
Smiley
« Reply #10942 on: January 22, 2019, 01:33:01 PM »
at last.
« Reply #10943 on: January 22, 2019, 08:20:57 PM »
Excellent, just the boost you need Mr. M to enliven your mojo!! Shocked
« Reply #10944 on: January 23, 2019, 06:04:37 AM »
Indeed. I definitely need re-mojoing.
« Reply #10945 on: January 26, 2019, 04:11:19 PM »
You should have told him you were coming to take them away months ago, then you would have had them that much sooner!   Grin Grin Grin
« Reply #10946 on: January 26, 2019, 04:34:56 PM »
They're not actually holding me up & while they were in Cardiff, they were out of my way Smiley
« Reply #10947 on: January 27, 2019, 09:25:13 AM »
Not knowing if they were being worked on was the problem!!!!
« Reply #10948 on: January 27, 2019, 10:48:43 AM »
Smiley
I pick up a hire van at 9 tomorrow morning so should be there before 12. Ifan said I could have them for free cos they've taken so long, but I'll pay him something anyway -don't expect anyone to work for free.
I think there'll still be stuff to do on them, so might be able to get that sorted while I wait for the weather to warm up enough to paint the chassis.
The edges needed welding all the way around the doors, where we trimmed them to fit the cab & the outside skins separated from the frames in a few places. Ifan hasn't mentioned doing that & has sprayed yellow paint on the edges, so I'll have to carefully re-hang each door & run a Tippex pen around the edges again.
The new interior window trims will also almost certainly need notching to fit over the ends of the dashboard before the doors can actually be closed.
Everything will be more awkward at the moment cos the back axle's out, so I can hang the passenger door in the confines of the lock-up, but not the drivers one, cos the Pop's too close to the wall on that side.
It's a starting point though. If the winder mechanisms work & the new runners are welded in, I could make templates & get new glass cut if nothing else.
« Reply #10949 on: January 27, 2019, 11:00:18 AM »
Saw these snaps from the American Grand National Roadster Show earlier.
Mine doesn't sit this low, but a similar overall look. I'm thinking of cutting the floor out of my pick-up bed too cos I'd like to show off the, (hopefully), shiny chassis & 4 bar set-up. We made the bed floor from corrugated steel sheet, which has ended up with several deep dents in it, (we stood a bike engine in the back at one point), & has a massively over complicated framework underneath.
I've already made a steel platform for the fuel tank to sit on, so will look at modifying the bed into just the 4 sides that can drop over the tank.
Yes, it's utterly impractical -it's a hotrod Smiley
« Last Edit: January 29, 2019, 12:12:41 PM by Manky Monkey » Logged
