March 29, 2024, 02:20:01 PM *
Pages: 1 ... 695 696 [697] 698 699 ... 791
Author Topic: Manky's Pop.  (Read 1537708 times)
« Reply #10440 on: May 17, 2018, 06:55:11 AM »
Unfortunately it comes out glossy..but I'm sure after a couple days/weeks/years it will mellow ,either road rash or dust ? Cheesy
« Reply #10441 on: May 17, 2018, 02:12:29 PM »
Hmm, definitely need to weather it down a bit then.
Maybe run a fine Scotchbrite pad over if to take the shine off.
« Last Edit: May 17, 2018, 02:15:51 PM by Manky Monkey » Logged
« Reply #10442 on: May 17, 2018, 04:57:25 PM »
Well all glued/painted..up to you to weather them mate..personally I'd just use the truck and they will get that weathers look in no time
« Last Edit: May 17, 2018, 04:59:21 PM by stinkey » Logged
« Reply #10443 on: May 17, 2018, 08:18:33 PM »
Smiley Thank you mate.
Are you about on Monday afternoon? 2ish?
« Reply #10444 on: May 18, 2018, 10:40:24 PM »
I've had a few days away from the Pop, just to recharge my batteries a bit & to let the lacquer harden before I start wet sanding again.
In the meantime though, I've been looking at the back end of the chassis & sorting a few things so I can run without the pick-up bed for a while, (the steel bed needs some modifying & a lot of prep & paintwork before it goes back on, so I plan to run leave it off for the time being).
I decided to fit a weight tube across the back of the chassis, to replace some of the weight lost by taking the bed off -if it's too light, the rear suspension won't move, making it a very harsh ride, & the rear brakes will lock up every time I touch the pedal.
So I bought a length of 4 1/2" diameter steel tube & cut out some flat discs to blank the ends. I've had captive nuts welded to the round plates to hold the rear lights, then the plates welded to either end of the tube. I am to wrap some flat steel strap around the tube & bolt it through the rear chassis rail. Just sat in place here.
I really hope the fabrication shop remembered to weld the captive nuts on before they fitted the end plates, otherwise when I unbolt the rear lights the nuts will fall into the sealed tube.
« Last Edit: May 18, 2018, 10:42:51 PM by Manky Monkey » Logged
« Reply #10445 on: May 18, 2018, 10:49:33 PM »
Then I canablised the numberplate bracket I made for the wooden bed that I've decided not to use. It's already shaped & drilled to  take the numberplate lights. It'll be welded to the tube.
« Last Edit: May 18, 2018, 11:07:41 PM by Manky Monkey » Logged
« Reply #10446 on: May 18, 2018, 10:58:24 PM »
I've got a pair of 60s Lucas style fog & reversing lamps, which I'll mount on brackets off the bottom of the tube, plus a spare pair of Lucas rectangular reflectors.
What's the capacity of a tube 30" long by 4 1/2" diameter?
I plan to drill some 1" access holes in the top, plugged with rubber blanking grommets, then once the tube's powder coated black, fill it with the heaviest stuff I can.
How much lead shot would it hold & where can I buy it in bulk? Any alternatives?
Spanners suggested shotblasting grit -would that be heavy enough?
BayChimp suggested concrete -would that go off inside a sealed tube?
« Last Edit: May 18, 2018, 11:06:30 PM by Manky Monkey » Logged
« Reply #10447 on: May 18, 2018, 11:03:43 PM »
I've also bought a chunk of 5mm steel plate as a platform to sit the fuel tank on. As well as being thick enough to ensure it doesn't bow under the weight of 8 gallons of fuel, it also adds a bit more ballast to the back end.
I need to trim it to shape, drill the mounting holes, then make up mounts for the handbrake cables, which will bolt or weld to the underside.
This'll be powder coated black too.
« Last Edit: May 18, 2018, 11:05:17 PM by Manky Monkey » Logged
« Reply #10448 on: May 18, 2018, 11:14:10 PM »
Got to mark & drill the mounting holes for the tank. It'll sit about 3" lower than this, so the swage line on the cab should be roughly level with the top of the tank.
The green looks completely different under different lights & is paler than these photos appear, but I'm pleased to say my cellulose aerosol job on the cab's a pretty reasonable match for the professionally sprayed 2 pack on the fuel tank.
« Reply #10449 on: May 18, 2018, 11:15:19 PM »
« Reply #10450 on: May 18, 2018, 11:16:09 PM »
« Reply #10451 on: May 19, 2018, 04:50:51 AM »
Volume of the tube is 7.8 litres. Weight of variable lead shot is 6.8 kg per litre so 53 kg
http://www.theleadweightcompany.co.uk/lead-shot-ballast.html.
« Last Edit: May 19, 2018, 05:28:24 AM by Olds » Logged
« Reply #10452 on: May 19, 2018, 05:52:23 AM »
Well first off..I love the look of the petrol tank..and having the weight tube at the back either Chromed/painted and on show looks funky Cool but I feel sticking the number plate on it somehow makes it look rather too busy at the back ? Huh But keep cracking on good sir..it's getting there..
« Reply #10453 on: May 19, 2018, 08:14:55 AM »
Thanks Dave. Is that heavy? In layman's, (idiot's), terms, what would that be similar to? A couple of bags if cement? Enough to make much difference or still light?
I found this Thames truck on FaceBook the other night. Obviously has the same problem -note the bags of cement strapped on the back Smiley
Steve -where do you think I should shove the numberplate? Smiley
« Reply #10454 on: May 19, 2018, 10:23:17 AM »
My only observation...........what a neat and tidy workshop!! never had one of those! Cheesy Cheesy Cheesy Cheesy
