March 29, 2026, 04:04:00 PM
Trike Tech
diff ratio
Topic: diff ratio (Read 2559 times)
diff ratio
February 15, 2007, 08:22:32 PM »
hi, has anyone any idea of diff ratio for 1600 beetle? im thinking about changing my wheels from 15" to 18" but not sure if the overall diameter is right for ratio/rmp/mph as it is now, about 24". is it bigger the wheel the more top speed?
any input would be good
regards
pete
Re: diff ratio
February 15, 2007, 09:55:25 PM »
Yeah, in theory, fitting bigger wheels will give you higher top speed but slower acceleration.
brock
Re: diff ratio
February 15, 2007, 10:08:47 PM »
Hi Pete,
I think that the standard ratio is 3.875:1 (just one of those numbers that you remember ) but the fourth gear is less than 1:1 , just had to look that up , it's 0.93:1 so your current setup (assuming 24" dia. ) should see you at 68.5 mph with four grand on the clock , in top. As Andy says , taller tyres more top end , but longer getting there. Depending on vehicle weight , engine tune I would think you could carry off a fair bit of an increase on those sizes.
Re: diff ratio
February 16, 2007, 12:18:07 PM »
hi guys, i think i can cope with a little more speed at topend and a little less acceleration as it can wheely in 2nd at least
it may be a good thing to stop me doing that
the power/weight ratio is pretty good and if it means a little better fuel consumption at a higher top speed then that sounds good to me. thanks.
suppose i'll be on the lookout for some wheels/tyres soon, wide with low profile
oh yeah...and cheap
harley gazz
Re: diff ratio
February 16, 2007, 03:12:45 PM »
pete i have 15 inch rims on my vw trike but have dirty great bf goodrich all terraine tyres on em still wheelies
great for getting off boggy campsites pulls a trailer a piece of pi** makes me smile naughty i know when others with their low profile tyres, are slipping about in the mud and i just hitch up me trailer and drive off
Last Edit: February 16, 2007, 06:35:20 PM by dynatrike
arc eye tha noo
