April 25, 2024, 04:57:52 AM
Trike Tech
Brake light switch
Topic: Brake light switch (Read 2725 times)
Brake light switch
October 26, 2021, 05:22:25 PM »
Hi Folks
I'm still around , what do people use for a brake light switch on a bike trike
Re: Brake light switch
October 29, 2021, 06:48:14 PM »
Hydraulic banjo bolt pressure switch works well, or a tee with a brake pressure switch somewhere in line. Later bikes have a built in switch in the front brake lever. For the rear, mechanical switches are OK but can be prone to moisture problems and adjustment issues.
I use a banjo bolt switch for the front brakes as I used a clutch lever/master cylinder.
October 31, 2021, 01:52:33 PM »
Thanks Dave
November 20, 2021, 01:22:22 PM »
Hydraulic switches are by far the best mines been on for the whole life of the trike and never had a problem.
November 24, 2021, 02:51:23 PM »
Thanks Twisted
