April 23, 2024, 05:30:08 PM *
Pages: 1 ... 4 5 [6] 7 8 ... 14
Author Topic: junkyard frog  (Read 52660 times)
« Reply #75 on: February 02, 2019, 09:34:22 PM »
not releasing Andy, tried all sorts. Just been told it should go if hot, seems the oil sticks the plates together, mind that is a facebook opinion  Shocked
Is there any adjustment on the clutch lifter pin.
« Reply #76 on: February 02, 2019, 09:52:34 PM »
Used to have to free the plates off on my Bonnevilles by kicking them over with the clutch lever pulled in & ignition off.
« Reply #77 on: February 14, 2019, 10:39:54 AM »
is it leaking from the cam oil seal still? Saw this and thought of it - https://www.heidentuning.com/xs650-shop/engine/camshafts-camchains-valves-guides/camshaft-side-covers-aluminium-1-detail.html
DESCRIPTION
Sold as a set (2 pc.)
Only for XS models with the ignition on the crank!
Stops oil leak problems on the camshaft.
« Reply #78 on: February 14, 2019, 01:52:51 PM »
No good unfortunately -the ignition's fired off a pick-up where the points used to be.
« Reply #79 on: February 21, 2019, 06:14:27 PM »
nice sunny spring day, took the frog for a not so gentle run. Got home to discover something missing !!
« Reply #80 on: February 21, 2019, 06:15:58 PM »
so retraced my steps, and lo and behold I found it in the gutter, unharmed but lonely  Cheesy
« Reply #81 on: February 21, 2019, 06:16:30 PM »
good vibrations................nope
« Reply #82 on: February 21, 2019, 08:04:59 PM »
Oh Jeez! It's still fighting every step of the way isn't it!
« Reply #83 on: February 22, 2019, 09:43:39 AM »
Yep, every step Andy. Wouldnt want it any other way  Cheesy Oil leak fixed, indicator wiring fixed again. Re timed and starts first poke. Oh and the circlip on the kickstart tried to make a run for it, but I caught it in time. Just bedding in problems, nothing horrid. Engine runs good, starting to get a feel for the handling, roll on hot summer, Please.
« Reply #84 on: February 22, 2019, 04:08:43 PM »
It's a lovely riding day here today & it's forecast to be nice all weekend -enjoy! Smiley
« Reply #85 on: February 22, 2019, 07:45:00 PM »
A worms eye view
« Reply #86 on: April 24, 2019, 07:41:26 PM »
just so you all know its still alive and fighting every step. Clutch stuck again, no more adjustment left on cable. Dig deeper. Head gasket leaking oil from ca chain area, seems a common fault. Fed up??? no, still teething trouble. Getting there, work in progress You all know the score
« Reply #87 on: April 25, 2019, 05:02:23 PM »
I admire your tenacity Sir
Id've set fire to it by now.
« Reply #88 on: April 26, 2019, 01:02:14 PM »
Gives a whole new meaning to doing a burnout.......... Cheesy
« Reply #89 on: April 27, 2019, 07:19:20 PM »
arghhhh!!! To change the head gasket, looking like a fuel tank off job, nope. Looking more like an engine out job. Starting to feel your pain Andy. New genuine gasket from Holland has arrived. Heres to next weeks work  Angry
