« Reply #105 on: November 14, 2019, 03:47:29 PM » |
It behaves more like a Brit bike than most of the Brits I've owned!  I did enjoy riding it when it was going well, but ran out of patience with it in the end, as well as realising I just wasn't enjoying biking in general like I used to.
« Reply #106 on: November 15, 2019, 07:57:01 PM » |
EUREKA !! today playing silly bu**ers in my cave, the clutch stopped working completely. A quick look in the adjuster hole and clearly see something is amiss. The worm drive thingy wotsit has fell to bits. Disaster I know, but at least I have now found something.
« Reply #107 on: November 16, 2019, 10:43:50 AM » |
Really? That was a new one. I replaced the original because it had done the same thing -it's a plastic screw thread & a chunk of it was missing. A sign of excess, (XS?), pressure or resistance maybe? I bought a set of uprated clutch plate springs, but think I re-used the softer originals because the new ones felt too stiff.
« Reply #108 on: November 18, 2019, 01:53:54 PM » |
I have ordered a brand new one from some tuner. He assures me that they now use a harder nylotron worm that is self lube and very smooth. So arm and leg removed and paid for
« Reply #109 on: November 19, 2019, 06:38:19 PM » |
Problem hopefully solved then
« Reply #110 on: November 22, 2019, 10:44:44 AM » |
 just been fiddling, those who saw the video of the clutch arm wiggling about will understand. Not only has the plastic worm drive collapsed, but the screws holding the assembling to the crank case has pulled the threads out. Bit miffed, spanners thrown, feet stamped, dummy spat.  So, the next step is helicoil or retap one size up. I think Andy was justified in getting rid. I'm not that way yet........yet.
« Reply #111 on: November 22, 2019, 08:15:56 PM » |
Soon 😱
« Reply #112 on: November 23, 2019, 09:04:22 AM » |
I feel your pain mate. Bigger size & threadlock the buggers. Still sounds like that worm drive assembly's under excessive pressure to me.
« Last Edit: November 23, 2019, 03:22:41 PM by Manky Monkey »
« Reply #113 on: November 26, 2019, 04:19:40 PM » |
tizzy's 'ere. ready to try again
« Reply #114 on: November 26, 2019, 06:03:29 PM » |
Good luck
« Reply #115 on: November 27, 2019, 12:08:10 PM » |
Sorted
« Reply #117 on: November 27, 2019, 07:52:14 PM » |
Curious.
« Reply #118 on: January 03, 2020, 08:32:37 PM » |
I'm still here, been a bit low and the wife has been ill, operation etc. Now my turn  BUT, I'm here still working on the frog in my spare time and hoping to bore you all with my travels and exploit during 2020.
« Last Edit: January 04, 2020, 06:28:06 PM by Manky Monkey »
« Reply #119 on: January 04, 2020, 06:32:04 PM » |
Hopefully we'll both be on the road in the Spring & could maybe meet up at a show somewhere.
