December 10, 2025, 06:38:17 PM
Jcb 3cx
Topic: Jcb 3cx (Read 2638 times)
peewee
Jcb 3cx
July 13, 2018, 09:58:48 PM »
Hi everyone just bought a jcb 3cx sitemaster for a job in my field and was just wandering if anyone on here has either owned one or worked on one so I can pick your brain about a couple of things.
Stix
Re: Jcb 3cx
July 13, 2018, 11:38:22 PM »
Reckon Spanner’s would be the go to guy
toad
Re: Jcb 3cx
July 14, 2018, 07:05:24 AM »
Yes me that's what I've been doing for the past 3yrs
Re: Jcb 3cx
July 14, 2018, 05:18:52 PM »
Toad you are a man of many parts!
peewee
Re: Jcb 3cx
July 14, 2018, 10:15:30 PM »
The model I've got has a sight glass on the side of the tank for the hydraulic fluid.should the black line be all the way to the top I put 10 leaters in and it didn't move.the tank I'm told holds about 120 leathers.i have a small leak on a hose so want to keep top side of it till I can sort it.
toad
Re: Jcb 3cx
July 15, 2018, 09:15:33 AM »
Don't always rely on the sight glass and don't worry about the level too much always dip the tank. The early ones use 46 hydraulic fluid but its not critical on those early machines your leak is probably a hose that is starting to perish pirtek can make you up a new one don't go to jcb as their prices are stupidly high.
Cheers
Toad
Re: Jcb 3cx
Reply #6 on:
July 17, 2018, 11:51:12 PM »
Quote from: Stix on July 13, 2018, 11:38:22 PM
Reading the rest of this thread made me feel ,redundant
peewee
Re: Jcb 3cx
Reply #7 on:
July 18, 2018, 05:25:40 AM »
Thanks toad.i put 30l of fluid in and it didn't even show.got another 20l to put in.also I'm going to put a new gasget in the gear box inspection as that as a small leak too.
peewee
Re: Jcb 3cx
Reply #8 on:
August 17, 2018, 08:03:01 PM »
Will the bolts in be metric or imperial.i took the bolts out of the radiator cover to clean and put new bolts in I thought they were 10mm but they wouldn't go in.i think it's a 1987 (e reg) so thought it would be metric but not sure.
toad
Re: Jcb 3cx
Reply #9 on:
August 18, 2018, 08:19:39 AM »
They could be either more than likely at that time a lot of parts were outsourced from overseas and they can be a right jigsaw puzzle to put back together again.
