April 16, 2024, 06:19:32 PM *
Author Topic: Trike. service work bench  (Read 5687 times)
« on: May 02, 2018, 08:02:26 AM »
I built this to make life easier for working on and servicing the trike. saves a lot of kneeling down when removing panels
« Reply #1 on: May 02, 2018, 08:17:17 AM »
How do you get the trike up on the bench then ? Roll Eyes
« Reply #2 on: May 02, 2018, 08:21:08 AM »
Lower it down
« Reply #3 on: May 02, 2018, 08:23:01 AM »
Nice bit of kit sir..worth making a few more ?
« Reply #4 on: May 02, 2018, 10:00:36 AM »
Um...  I can see that a bike would go on there but how do you fit the trike on, surely the axle is too wide?
« Reply #5 on: May 02, 2018, 10:17:15 AM »
Hi BG. I designed it to fit under the trike when not in use storage. it has extending arms on the rear beam the pull out and lift the trike under the axle leaving the rear wheel free
« Reply #6 on: May 02, 2018, 03:30:30 PM »
Nice Smiley
« Reply #7 on: May 02, 2018, 08:59:57 PM »
Clever clever stuff!    Smiley
« Reply #8 on: May 03, 2018, 08:33:49 AM »
The lift in on the floor. with the trike raised up to a comfortable working height. just need to sort out the front wheel support and safety lock stay. then get it painted
« Reply #9 on: May 12, 2018, 05:01:05 PM »
Garage all sorted no more builds. The Trike lift is all working so going to leave it for now. going to do a bit on the bike need to get it started and checked over may café race it.
« Reply #10 on: June 28, 2018, 08:22:36 PM »
I have done some modifications to the lift. nothing major just more user friendly. I have had made two arms that pick up the trike by the wheels this is more stable when working on it the other arm are fine and will be used. It can now be used for Motor bikes.
« Reply #11 on: June 28, 2018, 09:22:17 PM »
That looks more stable. Nice job Sir Smiley
« Reply #12 on: June 29, 2018, 05:41:05 PM »
Excellent!
« Reply #13 on: June 30, 2018, 06:25:43 AM »
Great bit of kit Terry.
« Reply #14 on: June 30, 2018, 07:00:31 AM »
Thanks for your comments. the 1st set of arms I used came with the cross beam lift and worked fine when you want to remove the wheels or service the brakes but you needed to strap the trike to the bench for safety . with these the trike sits firm when working on and I don't need the strap it down and it can use it for bikes as well now.
