April 30, 2026, 11:54:04 AM
General Tech
rewiring motorcycle clocks
Topic: rewiring motorcycle clocks (Read 5748 times)
February 24, 2018, 11:52:41 PM »
I need help.
I'm changing the clocks on the st1100 to a completely different set.The st1100 ones have a left and a right turn signal idiot lights built into the cluster. The new set has only one turn signal idiot light built in. Would any one know how i can wire the new set up so when i use the left indicator the idiot light would flash and when i use the right indicator the idiot light would flash. I can get it to flash by using one or the other st1100 one fitted to it but when i try to connect the two to operate the idiot light all the indicators flash like hazards. Can any one help.
dr big750
Re: rewiring motorcycle clocks
February 25, 2018, 02:48:26 AM »
Merv, try not using a negative earth, feed the bulb with positive power from left and earth with positive power from the right, only works with a bulb, not led, make sure bulb holder is not able to touch negative, will work as a bulb can be fed both ways, and will ground through the unused circuit.
Added on a pic, hope this makes it a little clearer.
Last Edit: February 25, 2018, 11:52:30 AM by dr big750
February 25, 2018, 04:19:32 AM »
This may help Merv
Living on a wing and a weld
February 25, 2018, 05:42:49 PM »
Now sorted thanks to the help from this site, i followed what dr big750 advised and it worked
February 25, 2018, 07:21:03 PM »
Jeez you was lucky? Nobody helped me ? Too bloody grumpy most like ?
February 25, 2018, 08:07:26 PM »
While an indicator lamp between the indicator feeds will work, the right way to do it, and one that will work with leds, is to use a pair of diodes, the anodes to the lamps, with the cathodes connected together feeding the indicator. This stops the backfeed between one side and the other.
Reply #6 on:
February 26, 2018, 05:20:48 PM »
Sorry, you totally lost me, without a diagram showing what to do i wouldnt have a clue.
I sort of know what diodes are but what on earth are anodes and cathodes
Reply #7 on:
February 26, 2018, 06:23:49 PM »
The cathode is the end with a stripe around it. No diagram needed, current only flows towards the stripe
Reply #8 on:
February 26, 2018, 09:55:00 PM »
Clear as mud, innit Merv? Vehicle electrix are a closed book to me, I always get someone else to look at mine.
Reply #9 on:
February 27, 2018, 02:59:08 PM »
Quote from: BikerGran on February 26, 2018, 09:55:00 PM
